New member with a cbr project
Old 07-21-2017, 05:01 AM
churny's Avatar
New wheels arrived, good and bad news.
The wheels will need spraying as they have been chipped and marked, however the brake discs are new and the tyre is in really good condition.
The bearings and seals have arrived for the front so the next jobs are forks and wheels. I plan on just painting the bottom of the forks as they have had new seals fitted and I intend upgrading them in the winter.
  #22
Old 08-08-2017, 07:55 PM
Shift96's Avatar
Originally Posted by churny
first job is tidy up the frame, I have ordered the paint. I plan on just touching up the bad bits as I don't want to completely strip the bike, the plan is to do a rolling restoration so I can still use it.
I have also removed the rear pegs and ordered a new exhaust hanger, quite a bit of metal removed those brackets seem excessively big.
Exhaust will need replacing, could do with some ideas about the replacement such as cost and suppliers. Unless a member has a spare used one.
will post some pics when I get home as working away for a week.
hi question where did you order the paint and what paint? Just picked up a 92 f2 project myself. Thanks
  #23
Old 08-15-2017, 10:32 PM
900rrGuy's Avatar
Where are you at on this project?
  #24
Old 08-19-2017, 04:23 AM
churny's Avatar
Quick update.
decided to not paint the forks as they cleaned up pretty well and they will be upgraded quite soon.
Fitted new bearing to the yolks and refitted the clip-ons.
The wheels are currently in primer but I'm going on holiday.
I will take plenty of pics when I get back.
I have also solved the problem with using a f4 rear shock. I was going to mount it on the left of the bike as the shorter hose fouled the coolant bottle. But have decided to just get a longer hose fitted and use the normal mounting point.
  #25
Old 08-20-2017, 06:02 PM
900rrGuy's Avatar
Outstanding......enjoy holiday!
  #26
Old 05-12-2019, 02:42 PM
churny's Avatar
Just wanted to post I'm still working on the bike �� Lack of time has ment slow progress but I should get it started tomorrow. I need to post some pics as it's been a long journey. Probably lots of questions now it's close to running..
Ive enjoyed it and am so looking forward to riding it ��
  #27
Old 05-13-2019, 03:43 AM
CaBaRet's Avatar
Be good to see them matey
churny
02-15-2017 08:27 PM
Ftwo90two
07-24-2016 02:49 AM
jake.carp
03-16-2013 11:26 AM
patpatpat
01-31-2011 04:42 PM
chris71383
04-24-2006 08:34 AM
Quick Reply: New member with a cbr project
