need help.Rectifier Regulator problem
Old Oct 24, 2005 | 11:17 AM
japspec's Avatar
Default need help.Rectifier Regulator problem
wassup guys,does anybody know or have a problem with there rectifier regulator. cuz mine keep getting too hot when i mean too hot is one of the wire getting burn. what im tingking is i might have have a shorted wire somewhere.but just wondering if anybody has they same problem.
anyway this for 91 cbrf2
thanks,
Old Oct 24, 2005 | 11:55 AM
MofoSachem's Avatar
Default RE: need help.Rectifier Regulator problem
some people have said that they needed to make a custom heat absorber for the Volt Rec. you might need a new one. I have seen them on ebay.
Old Nov 2, 2005 | 12:51 PM
japspec's Avatar
anybody can help?
Old Nov 2, 2005 | 02:05 PM
ryen99's Avatar
I had the same problem. On my bike the frame acts as the heatsink. Put cpu grease between the frame and regulator.
https://cbrforum.com/m_31382/mpage_1/key_/tm.htm#31705
I had 2 problems, one there was a bad connection between the alternator and regulator probibly caused by to much heat. Two I had to put heat conductive grease between the regulator and frame to disapate the heat.
After a long ride the frame around the regulator gets really hot probibly 150 F
The connector attached to my regulator also melted.
MAKE SURE ALL OF YOUR Light bulbs are working. The less power your bike uses, the more extra power your regulator will turn to heat and the hotter your regulator will be.
This explans it well
http://www.inwa.net/~m3047/rect-reg/rect-reg.html
Old Nov 2, 2005 | 02:36 PM
japspec's Avatar
also my head light not working, i have change the rectifier regulator and stator magneto but still my rectifier get so hot. as soon i start the bike within 30-40 second its already hot.
Old Nov 3, 2005 | 01:58 AM
clemson725's Avatar
The old models had the eletronic components set in rubber. The newer ones have fins to cool it down. I definitely recommend the newer style. Also on the F2 i had, I took a small 12v electric fan that cools the processor in a desktop computer and rigged it over the regulator/rectifier to aid in slow speed cooling. I never had any trouble after that.
yauhen
F2 Tech
111
Jul 11, 2023 12:40 PM
F4iMane
Nov 2, 2011 11:10 AM
Asmittie84
Sep 15, 2010 10:29 AM
CBR lulz
Jul 23, 2009 07:13 PM
silentassassin
Mar 8, 2006 09:23 PM
