regulator/rectifier is common problem or no??
Old Aug 27, 2008 | 07:15 PM
F4iMane's Avatar
Default regulator/rectifier is common problem or no??
Just wandering is a regulator/rectifier problem common for a 03 F4i??? If so what are the symptoms that it is about to go?
Also can riding at high speeds, say 100 mph or more cause more stress on it? Do high speeds create more current through it or does your speed not really change how hard the regulator/rectifier has to work??
________
Avandia Classaction
Old Aug 27, 2008 | 07:32 PM
f4ez's Avatar
Default RE: regulator/rectifier is common problem or no??
ive never had any issues with mine but i am having that damn rattle from the cct
Old Aug 27, 2008 | 08:26 PM
Xuracing's Avatar
i had a problem with it not really working it was a loose connection
Old Aug 27, 2008 | 10:45 PM
itgbudeev's Avatar
to answer your question... yes the regulator/ rectifier is a fairly common problem with F4i's and i can;t really answer your "high speed" question
Old Aug 27, 2008 | 11:15 PM
chainstretcher's Avatar
Admin Emeritus & MVN
I have wondered about the speed question myself. It generates more at high rpms but it also consumes more.
And the answer is YES ... Honda, for all its brilliant sophisticated bikes, makes crappy power generation systems for those bikes. First sign the regulator is going would be chronic low charged battery. If your battery is fairly new and it barely cranks the bike then I'd look into the alternator and regulator. I changed mine (1kRR) with some aftermarket 'high performance' parts and it has made a world of difference.
Old Aug 28, 2008 | 08:55 AM
F4iMane's Avatar
ORIGINAL: chainstretcher
Interesting, and ya I am still wondering about the high rpms myself
________
AVANDIA CLASS ACTION SETTLEMENT
Old Aug 28, 2008 | 10:13 AM
WOT's Avatar
WOT
ORIGINAL: F4iMane
Is there a specific problem with your bike? It's there to regulate the current, it either works or it doesn't regardless of your speed. You can rev your bike and watch your headlight modulate to indicate if it's working or not. The only bike I ever had a bad regulator on was my SV650 that was dropped on the regulator side. It's typical if a bike is dropped to damage it.
Old Aug 28, 2008 | 10:36 AM
F4iMane's Avatar
ORIGINAL: WOT
ORIGINAL: F4iMane
What do you mean you can rev the bike and see if the headlight modulates or not? How so?
________
WELLBUTRIN SETTLEMENT UPDATE
Old Aug 28, 2008 | 10:47 AM
WOT's Avatar
WOT
Ever notice your headlight dim when you rev a bike? the reason is the regulator/rectifier is working properly.
Old Aug 28, 2008 | 11:43 PM
That's with the Honda stock alternator and reg/rect ... put on some good aftermarket stuff and the lights won't dim when you're idling. And your battery will last longer.
