Need clutch help bad!!!!
Old Apr 2, 2008 | 06:56 PM
smokeydtdt's Avatar
Default Need clutch help bad!!!!
I have a 93 F2 and the other day I went out to start it and take off and I started it in neutral let it warm up then when I dropped it into fist it died. I assumed it was the clutch so I replaced the plates, disk, and springs. But still no go. If I try to start it in gear with the stand up it lunges forward. I am stuck and need some help.
Old Apr 2, 2008 | 07:18 PM
tao_victim's Avatar
Default RE: Need clutch help bad!!!!
err was the kick stand down?
Old Apr 2, 2008 | 07:27 PM
smokeydtdt's Avatar
No it wasn't but i did try it both ways up and down and it did the same thing.
Old Apr 2, 2008 | 09:47 PM
MikeZ's Avatar
From: Granger, Indiana (Next to South Bend and Notre Dame)
When you are trying to start it in gear are you holding in the clutch? Also, if the bike lunges when you have the kickstand down and in gear trying to start it that seems odd since it shouldn't even attempt to start.
Old Apr 2, 2008 | 09:51 PM
reydelaplaya's Avatar
With the clutch lever engaged, can you easily switchthrough thegears, while the bike is off? This sounds like maybe the clutch cable has stretched, not allowing clutch disengagement. Have youtweaked the bottom clutch cable adjustment? If it's maxed out, it might be time for a new cable.
Old Apr 3, 2008 | 01:03 PM
MikeInCtown's Avatar
With the clutch lever engaged you should not be able to go through more than a few gears,and even then there will come a point when you won't be able to select any gear without rolling it forward.
As someone else asked, will it start when you have the lever pulled in while the bike is in gear? Does it just die when you let the clutch out, or does it die even with the lever engaged in any gear besides neutral?
Old Apr 3, 2008 | 06:42 PM
smokeydtdt's Avatar
It only starts when its in neutral. When i shift into first it dies. If i try to start it in gear with the clutch pulled in it starts to take off like the clutch is out but ill be holding the clutch lever in. Im going to get a new cable and try that. cause i did try to adjust it all the way out and it still acted up. Im just worried its someting to do with the tranny but everyone i have talked to said it sounds like a clutch problem.
Old Apr 3, 2008 | 07:52 PM
GARMIN1000F's Avatar
clutch issue, sounds as if the cable is not adjusted right.
Old Apr 4, 2008 | 07:54 AM
Not tranny issue. Clutch is the only thing that engages and slips. Now if you shifted and let the clutch out and still didn't move, then you'd be screwed. LOL
Good luck on the new cable. Also, what brand of oil is in there now, how long has it been in there, and do you need to top off? Using oil with modifiers not intended for wet clutches can have adverse affects.
Old Apr 4, 2008 | 08:31 PM
smokeydtdt's Avatar
thanks for all the help and suggestions. I get the cable on tuesday. ill let you know how it goes. thanks again.
Zandaloo
Aug 22, 2013 03:26 PM
Bordo
Sep 21, 2012 07:33 PM
02f4irider
Mar 6, 2009 07:50 PM
red stinger
Jul 19, 2008 12:17 AM
cyber00677
Jun 23, 2007 06:17 PM
