my chain keeps loosening by itself within 1 hour ride.
Old 08-13-2009, 04:41 PM
CaliKush's Avatar
Default my chain keeps loosening by itself within 1 hour ride.
so the title basically said it all. yesterday i tightened my chain for it to have a 1 inch slack... i went riding with my friends for about a hour and i went to check up on my chain n now the chain slack is like 2-3 inches.. and its able to touch the swingarm.. anyone know what i can do to prevent this from happenin again?
BTW> this is not a one time thing.. it happens over.. and over.. and over...
Old 08-13-2009, 08:15 PM
Polonius's Avatar
How old is the chain? Sprockets? Where are the slack adjusters lining up in the swingarm?
Sounds like ancient chain to me.
Old 08-13-2009, 08:58 PM
Dissevered's Avatar
if it is an old chain, it will stretch a lot. if it is a new chain that isn't pre-stretched it will also stretch a ton before it finally settles
Old 08-14-2009, 06:39 AM
CaliKush's Avatar
its actually a 1 month old chain and sprocket set.. but i found out what it might be.. so me n my friends went out for a ride for about an hour then we hit up a stunt spot.. did a couple wheelies then i stopped and check out my chain.. and i saw at the end of the swingarm(on the sprocket side), where theres the bolt that adjusts the chain tension and the bolt tightens down the alloy piece.. that alloy(or alluminum) piece was BROKEN in half and im missing the other half(somewhere long gone on the freeway).. and just hanging by some threads.. what do i do about this?! surprizingly i made the 1 hour ride back home safely...
Old 08-14-2009, 08:04 AM
Sand.Man's Avatar
What do you do? You replace it lol.
Old 08-14-2009, 10:25 AM
cajunlowrida's Avatar
Ya as long as your axle is tightened to spec you'll be ok without one of them while you wait for a new one
Old 08-17-2009, 08:51 PM
Polonius's Avatar
Those are called chain slack adjusters, and are there to make adjusting the chain slack something easier than a suicide-inducing nightmare. With the axle slacked, you can make very fine adjustments to the axle position with them. Otherwise you'd have to move the axle directly, making it a nightmare.
Doesn't really answer your original question, though. Is the axle torqued correctly?
Old 08-18-2009, 02:41 AM
CaliKush's Avatar
mmm negative. i'm one of those home-mechanics that just enough tools to get you by. which means no torque wrench =[. however i tightened this by hand. i stood on the other ride of the exhaust and i was leaning a little over the seat while pulling withhh all my might to tighten the axle bolt.. i puled hard enough to where the bike lifted to my stomach, and the rear shock compressed like a quarter way up.. but im no puff guy 6'2 155.. lol
Old 08-18-2009, 07:47 AM
Viking's Avatar
Sounds like you overtightened it - ALOT!
If you do not know how much to tighten - it is always better to undertighten than to overtighten.
Old 08-18-2009, 09:54 AM
johnnyx's Avatar
Yeah, that was one thing that amazed me about these bikes - the torque on most of the bolts, even the axles is VERY low. I went and bought a torque wrench out of fear of over-tightening everything. I know they're pricey, but it's one of those things you'll use all the time once you have it. Just be sure not to throw it in the drawer with the rest of your tools, cuz it'll get de-calibrated. Keep it in it's protctive box.
jpanside@gmail.com
02-19-2014 11:36 PM
playb0i
08-01-2010 02:48 AM
K7inne09
02-12-2010 05:31 PM
CeeBeeAre600
05-29-2009 08:14 AM
Ericy05
09-28-2008 10:46 AM
Quick Reply: my chain keeps loosening by itself within 1 hour ride.
