Help with loosening oil drain valve
Which way am i suppose to turn the bolt for the oil drain bolt if i am on the left side (opposite from the exhaust)?
I swear the god, the previous owner that did a oil change used a industrial electric drill to screw it on, Its on ridiculously tight, turning both ways feels like its tightening the valve.? Someone help
RE: Help with loosening oil drain valve
just find out what size the screw is...then buy a tap for the next size bigger and tap it out. Then buy a bolt that will seal it and put some rtv on the bolt to make sure it ghetto-ly seals.
if you can throw old oil back in for a min to get the metal shavings that may be in there..out. I bet most of the metal comes out though.
