my bike is acting weird???
Old 04-24-2006, 01:41 PM
92CBR600_22's Avatar
Default my bike is acting weird???
when cold start i pull the chocke down, it starts fine then after 1 min or 2 i close the chocke and the bike dies, or it idles under 1k??? any suggestions
Old 04-24-2006, 05:21 PM
MT Wallet's Avatar
Default RE: my bike is acting weird???
try and adjust your idle using the idle screw.... maybe the idle is too low
I forget which side of the bike it's on, but if you're sitting on it, should be within reach to your right or left.
Old 04-25-2006, 01:48 PM
the manual says at 20k i need to do carb idle speed adjustment, and vavle clearnce adj.
Old 04-25-2006, 06:04 PM
MT Wallet's Avatar
my bike has over 23,000 miles and I don't think the valves have been checked even once...
I don't think the carbs have ever been checked either...but she runs fine. or at least seems to .
the Honda mechanic said he's seen bikes with up to 60,000 miles and only one valve clearance check....it's usually an inspection only.
but others will probably disagree with that
Old 07-12-2006, 03:30 PM
I had a very similar problem with my F2... turns out the fuel line was pinched underneath the tank... check the S shaped line under the tank to make sure its not pinched.
Roman30
04-25-2012 02:49 PM
motogpman
09-07-2009 12:28 PM
BStrand29
04-26-2009 01:43 PM
kray923
04-07-2009 12:42 PM
Twiztid CBR
07-22-2008 04:20 PM
Quick Reply: my bike is acting weird???
