my bike is acting weird???
try and adjust your idle using the idle screw.... maybe the idle is too low
I forget which side of the bike it's on, but if you're sitting on it, should be within reach to your right or left.
my bike has over 23,000 miles and I don't think the valves have been checked even once...
I don't think the carbs have ever been checked either...but she runs fine. or at least seems to .
the Honda mechanic said he's seen bikes with up to 60,000 miles and only one valve clearance check....it's usually an inspection only.
but others will probably disagree with that
