motor dimensions question
Old Dec 22, 2008 | 05:50 PM
Hurricane rider's Avatar
Default motor dimensions question
Could I get someone to take some measurements for me on their F2 motor?
I need the distance from top to bottom on the two rear mounting holes from each center, the width of the engine case at each rear mounting hole, and the width to the mounting points on the very front of the engine.
The rear mounts on the cylinder may be used, but are unlikely. I suppose the distance to the outside of those could be useful to me too. why not?
I need this information to find out if I can use the F2/F3 motor for a very custom swap I'm planning to do.
Old Jan 5, 2009 | 02:17 PM
ALV's Avatar
ALV
Default RE: motor dimensions question
Hello Hurricane rider!
It just happened that I took off the side fairings for some cleaning and then I saw your topic.
I didn't really understand what measurements you asked for, but I reckon that these are the ones you requested (check the pictures):
For the distances that can't be seen on the pictures, I marked the bolts with colours, so: between - the green bolts, from left to right (or right to left) there are approx. 34.5 cm or 13.58 in (couldn't really measure exactly because between them there is the oil cooler)
- the blue bolts the distance is 35 cm or 13.78 in
- the yellow bolts the distance is 23.5 cm or 9.25 in.
Hope this helps you, if it doesn't please let me know and I will measure it again.
[IMG]local://upfiles/13044/D0368739F5C7403F9AAFF175B026CECE.jpg[/IMG]
[IMG]local://upfiles/13044/0F6CC11F823840D0B361FCB3AD71B82D.jpg[/IMG]
Old Jan 5, 2009 | 02:32 PM
Thanks, those particular numbers dont really tell me what I really need though.
Old Jan 5, 2009 | 02:39 PM
ALV's Avatar
ALV
Put some pictures and mark on them the measurements that you need and I will measure them if I can
stalemate27
Jul 23, 2008 04:13 PM
newnut
Jul 6, 2008 09:28 PM
killerc998
Jun 24, 2008 04:33 PM
killerc998
Jun 23, 2008 11:00 PM
six00RR
Aug 28, 2007 02:19 PM
