Lumpy idle, slight hesitation under light throttle
Okay, here we go. I have a '91 CBR F2 with 19k on the clock. I've cleaned and synced the carbs and replaced the spark plugs. The idle is pretty lumpy and under part throttle there's a bit of a mis-fire but as soon as I get passed maybe 10% throttle angle the misfire is gone, it's not as bad now that it's been sync'd and new plugs. I'm thinking it might be a coil or the pilot screws need to be removed and cleaned then re-adjusted. When I cleaned the carbs I did not remove the pilot screw/adjusters. Here's how it sounds now.
ok, k n and bmc are better for bikes with ram air. we don't have that. the problem is the free er flowing filter creates too much turbulence where the your fuel atomizes there for reducing overall smoothness and power. its more evident in the mid where your needle is not fully open. your flat spot could be the filter but is more likely to be a jet kit.
Stock will filter better though.
As for fast tracks. I would adjust the pilot screws. Let it idle with the choke off for a few minutes and take your plugs out. Wet? brown? light/tan/dry? Turn pilots out to richen and in to lean out.
