left side case
Old Mar 20, 2008 | 09:47 PM
quadracer18's Avatar
Default left side case
I recently bought my f2 off of a guy who dropped it on the left side. WHen the bike fell it scraped up the left side cover for the motor pretty good, I want to take it off and repaint it, is there fluid behind the cover that i need to drain or is it okay to unbolt it right away?? It looks to me like the stator is behind that cover, am i right? thanks, Josh.
Old Mar 20, 2008 | 09:59 PM
bindelsf2's Avatar
Default RE: left side case
you will get oil out of there but not much..if you can try and lean it tothe other side and you will be fine..behind there is the stator,starter and starter gear.. just make sure that you get a new gasket before hand so you dont have alot of down time!
Old Mar 21, 2008 | 10:35 AM
is there a bolt under the motor to drain that area so i dont have to tilt the bike or is it just an area oil finds its way in to? Thanks buddy! btw, does that rear f3 tail, taillight and seat bolt right up to an f2 without modification? Im thinking about doing that.
Old Mar 21, 2008 | 03:16 PM
bindelsf2's Avatar
no theres no bolt there.but its only a little oil not alot.
the f3 tail is a direct fit, you just need a f3 taillight bracket,taillight and seat.
huricanetommy1.0
Aug 31, 2015 05:19 AM
XXCBRChrisXX
Mar 15, 2008 09:02 PM
CosmoBob
Apr 20, 2007 02:59 PM
