left crank case cover question
Old 03-15-2008, 03:51 PM
XXCBRChrisXX's Avatar
Default left crank case cover question
hey i do dirt or anyone got a leaky side cover on left side of engine. took off plastic cover and the bottom bolt that holds the brass triangle part on. its leakin from there. but i dont see any hole. and the bolt is still tight. so thought i would ask the wise forum.
thanks
Old 03-15-2008, 06:39 PM
Default RE: left crank case cover question
When I bought my '96 I had the same problem. I've also seen numerous posts in here bout the same thing. My bike had been dropped and it forced the bolt you mention into the cover. Not enough to notice, but just enough to put a hairline crack in it. I did exactly what everyone in this forum said..... pull the cover off, JB weld the inside where the crack is, and then I made a gasket out of a manilla folder and ball peen hammer, used some gasket sealant and....Voila!! a fix that only costed about 10 bucks!!
Old 03-15-2008, 09:02 PM
GILL's Avatar
yep just fixed up mine, see the post.....
https://cbrforum.com/m_493607/tm.htm
Toolbox
07-05-2012 07:40 AM
dizzie56
04-30-2007 04:41 PM
Quick Reply: left crank case cover question
