carbs floding? or not synced right?
Old Mar 20, 2008 | 12:41 PM
GARMIN1000F's Avatar
Default carbs floding? or not synced right?
Just bought my girl a 92 f2 for $1500 cash. great deal i thought, but after replacing the tires, chain, clutch, lights in the dash, and fairings its startin to get to me.
I was riding the bike into work today and notice no matter what i couldnt get it past 75mph.
if i cracked the throttle in 1st or 2nd it was great power but in any other gear the bike seemed to flood, and even had a little "jerk" where the bike would pull for a sec then kinda lurch forward. this was at 60 mph and it was barely noticeable.
but the bike will not go any faster than that.
Old Mar 20, 2008 | 12:48 PM
smitty911's Avatar
Default RE: carbs floding? or not synced right?
i paid 1900 for mine and it runs great. i bought it right before winter and it was boggin down on me alot. i got it up to way faster than i need to go lol but it still ran bad. i tried putting in carb cleaner but it didnt do much. but after i changed the plugs its runnin fine. did you check the plugs out at all?
Old Mar 20, 2008 | 04:48 PM
im going to change those tonight but i think the carbs are dumping way to much fuel in the motor
Old Mar 20, 2008 | 05:18 PM
kjohnson's Avatar
Go to Advance Auto to get your plugs.Tell them you want plugs for a 2000 CBR929.29 dollars and change out the door.You won't beat that.
Old Mar 21, 2008 | 12:34 AM
alejandrof2's Avatar
that happen to my bike, runs perfect to around 7500 rmp gets up to 75 in 6th gear but after that start running weird, my bike was seatingin a garage for a wile so i get a rebuilt carb kit, new plugs, plug wires, problem solve.btw i try the sea foam carb leaner and lucas injector cleaner and both do nothing but smokemy drive way very bad
Old Mar 21, 2008 | 07:33 AM
i replaced the plugs, they didnt look bad but the insulators were starting to burn. pulled the carbs and cleaned them last night. had to get some sleep for work but ill throw it all together tonight and go test her out. Also going to have a buddy of mine sync the carbs this weekend.
Old Mar 21, 2008 | 11:04 PM
one of the jets had to be clogged. went out tonight with clean carbs, put back the stock airbox "snorkels" bike sounds a lot different but runs to much damn better its amazing. put the tire towards the sky in 1 and 2nd tonight. going to put her through a thorough test tomarow and just run her like a dog
evillecbr812
Jul 1, 2010 09:22 AM
CBRfenatic93
F2 Tech
Mar 15, 2010 08:41 PM
riegnman
Jul 29, 2008 01:47 PM
telgren
Apr 5, 2007 11:58 AM
