LED relay?
Old May 31, 2016 | 03:19 AM
damion1986's Avatar
Default LED relay?
Hi guys im sorry to keep up with more posts but im struggling to find the answer on here, i have currently 2 LED indicators on the front of my F2 and the old ones the rear, however the indicators are flashing fast, but when i replace the old rear indicators for LED they stop working all together?
Do i need to change the relay for an LED relay or is there something ive missed? Also if it is an LED relay is there any type i need to go for? Links to ebay would be desirable.
Many thanks.
Old May 31, 2016 | 02:17 PM
Phil314's Avatar
Many thanks.
Some LED blinkers have build in resistors, some don't. Ones without will blink too fast using the stock relay. You can add resistors, you could buy better turn signals, or buy a LED relay like this
https://tstindustries.com/LED-Flasher-Relay-Gen2.html
Old Jun 1, 2016 | 12:21 PM
damion1986's Avatar
Thank you for the tip and link but mines a 3 pin I was looking at one like this... Fix Flash Rate Turn Signal [Flasher Relay LED indicator bulbs] 3 PIN CF14 JL-02 | eBay
Would this be ok for the f2? Im more than happy soldering the connection to stop resistance heat.
Old Jun 2, 2016 | 04:09 PM
Phil314's Avatar
Well, they have this one too:
https://tstindustries.com/2-Pin-LED-...ay-Gen2-F.html
However, It is my understanding that most 3 pin flashers only use 2 of the pin. So you need to go by the pin configuration, not pin numbers.
Either | | | (like the first one) or | _ | (like the second link)
I believe the F2 uses the first one and the first link I sent should work for you, unless UK F2 are very different from US F2's.
jag007
Apr 22, 2013 08:49 PM
jawz0414
Dec 16, 2010 05:03 PM
muckdawg24
Sep 17, 2007 12:13 PM
zero7cbr
Aug 17, 2007 10:59 PM
jawz0414
Oct 17, 2006 03:40 PM
