LED relay?
Hi guys im sorry to keep up with more posts but im struggling to find the answer on here, i have currently 2 LED indicators on the front of my F2 and the old ones the rear, however the indicators are flashing fast, but when i replace the old rear indicators for LED they stop working all together?
Do i need to change the relay for an LED relay or is there something ive missed? Also if it is an LED relay is there any type i need to go for? Links to ebay would be desirable. Many thanks. |
Originally Posted by damion1986
(Post 1295734)
Do i need to change the relay for an LED relay or is there something ive missed? Also if it is an LED relay is there any type i need to go for? Links to ebay would be desirable. Many thanks. https://tstindustries.com/LED-Flasher-Relay-Gen2.html |
Thank you for the tip and link but mines a 3 pin I was looking at one like this... Fix Flash Rate Turn Signal [Flasher Relay LED indicator bulbs] 3 PIN CF14 JL-02 | eBay
Would this be ok for the f2? Im more than happy soldering the connection to stop resistance heat. |
(Post 1295747)
Would this be ok for the f2? Im more than happy soldering the connection to stop resistance heat. https://tstindustries.com/2-Pin-LED-...ay-Gen2-F.html However, It is my understanding that most 3 pin flashers only use 2 of the pin. So you need to go by the pin configuration, not pin numbers. Either | | | (like the first one) or | _ | (like the second link) I believe the F2 uses the first one and the first link I sent should work for you, unless UK F2 are very different from US F2's. |
