just picked up a 91, needs some work, any suggestions?
Old Nov 4, 2013 | 04:47 PM
asbjones's Avatar
main fuse blown! and its only a 20 amp, should'nt that be a 30?
Old Nov 4, 2013 | 04:48 PM
asbjones's Avatar
Originally Posted by campos_motorsports
Usually when everything is dead, it will be the 30a fuse under the seat bro, goodluck.
ah yes 30!
Old Nov 4, 2013 | 04:54 PM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Old Nov 4, 2013 | 06:11 PM
asbjones's Avatar
ok so fuse is in and lights come on and start button clicks, but I think the stator cover is smashed in to hard, the starter ring gear moves just a little but the motor doesnt turn over, Im going to try to and get the cover off, I might need a stator along with the cover...
Old Nov 4, 2013 | 08:23 PM
squale147's Avatar
July 2013 ROTM
Originally Posted by JNSRacing
Like a couple of the guys already said, it's probably your main fuse or relay.
If you look on the battery box, on the left side, you'll see where the relay sits, in front of the battery.
You'll see a connector with a red locking-tab cover, which plugs the positive cable into the relay unit - remove this, and you'll see the 30 amp fuse plugged in... if it's good, you might have a bad relay, or there may be a severed wire elsewhere in the harness, if it's bad, there might be a spare inserted in a little slot below the relay, with the top of the fuse facing the left side of the bike.
Good luck!
agreed...
Old Nov 6, 2013 | 01:09 AM
asbjones's Avatar
so the bike is either stuck in gear or the engine is froze or the stator cover is so smashed it wont let the motor spin somehow
still trying to get the stator cover off , I think its more smashed on than I thought, really strange as Ive been pying on it for awhile now
Im also going to pull the plugs and see if it will turn over from a bump start, hopeing the engine isnt seized or something major going on...
Old Nov 7, 2013 | 02:53 AM
asbjones's Avatar
got the stator cover off and the stator out! and now it turns over!(used a piece of the cover to hold the starter mid gear in place) I also pulled a plug and it has a nice spark, gonna try adding gas tommorow and see what happens
the stator and stator housing Im going to have to replace, hopefully they are'nt too much...
Old Nov 10, 2013 | 11:11 AM
asbjones's Avatar
It runs! Put some gas in the tank and a lil starter fluid, but a good amount of oil came out the stator side , hopefully its just because the cover is off
Old Nov 10, 2013 | 01:27 PM
JNSRacing's Avatar
Yeah, the cover is needed to contain the oil, and you mentioned in your first post that the casing was chipped as well, has this been addressed yet?
Old Nov 12, 2013 | 12:16 PM
asbjones's Avatar
Im going to replace the cover, stator and flywheel then I ll have to seal up the chiped edge of the case with something, its about 2 inches long and a 1/4 inch deep...
do I need a puller bolt to get the stator flywheel off? I saw them on ebay...
