just picked up a 91, needs some work, any suggestions?
Hi CBR Guys,
I just picked a 1991 CBR 600 in fair shape...
its almost complete but has a broken stator cover, missing the front calipers and rotors, missing a seat, rear tail light assembly, and needs to have the radiator hoses hooked up and probably more
The stator cover Im concerned about as the bottom of the case is chipped, I dont think oil runs in that area as the dipstick shows oil in the case, so question is can I just fix the outer cover and it could be ok?
Think I downloaded mine from here:
MC "Black Bears"
Might wanna give the file a quick scan if you want to print it out make sure you have a good laser printer, I did cause I wanted to take it to the garage, the complete printout is like an inch thick...
MC "Black Bears"
Like a couple of the guys already said, it's probably your main fuse or relay.
If you look on the battery box, on the left side, you'll see where the relay sits, in front of the battery.
You'll see a connector with a red locking-tab cover, which plugs the positive cable into the relay unit - remove this, and you'll see the 30 amp fuse plugged in... if it's good, you might have a bad relay, or there may be a severed wire elsewhere in the harness, if it's bad, there might be a spare inserted in a little slot below the relay, with the top of the fuse facing the left side of the bike.
Good luck!
Good luck!
