how to strip a tank?
Old Feb 5, 2010 | 02:33 PM
CBRme's Avatar
Default how to strip a tank?
how do you get the stickers off the tank with out getting to carried away...any ideas?
Old Feb 5, 2010 | 05:52 PM
jk72180's Avatar
short answer you cant they are under the clear. you can sand them off, which takes entirely too long, or go the route i did and use aircraft stripper. a little bit messy but takes like 15 min.
Old Feb 5, 2010 | 05:54 PM
Kuroshio's Avatar
Ya, if they're under the clear your only option is to remove it all. If you're lucky and they're on the clear, a hot hair dryer will loosen the glue and let you pull them up. Then you need something to remove the residue.
Old Feb 6, 2010 | 04:22 AM
kray923's Avatar
heat gun and adhesive remover, if there under the clear cloat, is it time for a new paint job??!!
Old Feb 6, 2010 | 07:56 AM
CBRme's Avatar
i think i will buy the exact same stickers and put them over the top...sound like a good idea?
Old Feb 6, 2010 | 04:03 PM
kray923's Avatar
why do you want to remove the stickers in the first place if your just going to put new ones on?? Cover them, only you would know the difference
Old Feb 6, 2010 | 07:16 PM
CBRme's Avatar
i want to paint the bike black with white stickers
Old Feb 7, 2010 | 12:23 AM
jk72180's Avatar
then just sand them off you will be alot happier with it in the end
CBRBoomer
Jan 28, 2011 03:52 PM
Ziggyman
Sep 27, 2010 04:32 PM
murdocity
Oct 29, 2009 05:02 PM
rrspeedster88
Dec 5, 2008 01:39 PM
Supersteve911
Jul 27, 2005 03:06 AM
