how to adjust idle
Old Dec 25, 2007 | 11:54 AM
mrb's Avatar
mrb
Default RE: how to adjust idle
Here is a picture of the idle adjustment screw location, keep in mind I have the fairings removed in this picture...
[IMG]local://upfiles/22822/9B39ED7AA402403490DF20E8F754A127.jpg[/IMG]
Old Dec 25, 2007 | 05:01 PM
1993CBR's Avatar
i've had it up around 3k rpm idle and as soon as i slide the choke to the off position it shuts down....it's a problem i am discussing on some other boards....thinking it's poissibly a clogged pilot jet....
Old Dec 26, 2007 | 12:06 PM
mrb's Avatar
mrb
Let me know what comes about of your idling issue, if it is indeed in the carbs, thats a little beyond my knowledge, but would like to know how to correct it for future reference.. Good Luck
Old Dec 26, 2007 | 06:20 PM
amanc96's Avatar
I just got my CBR a few days ago. I too was having the same problem. I ended up adjusting the idle screw turning it clockwise like mrb said and it fixed the problem. Good luck.
Old Apr 10, 2019 | 02:24 PM
Brandon Rolley's Avatar
Default Please help
I have got a 94 cbr 600 f2 its idling at 3000rpm and I cannot find anything on the bike or web to show me where the adjustable screw for the idle is, just to get to the cable you've got to take off the air box tank and plastics yet you cant adjust it if everything is unhooked
Old Apr 10, 2019 | 03:17 PM
Phil314's Avatar
If you are talking about idle mixture, then there are 4 screws, one at the base of each of the carbs. That screw affects the lean/rich mixture at idle.
If you are talking about idle speed, then you should have a black **** on the end of a 12 inch cable.
It comes out the left side fairing and turning it counter clockwise will lower the idle speed.
It sometimes gets hidden behind the left side fairing, so you may need to pull the fairing to see it.
Old Apr 10, 2019 | 03:23 PM
I have checked for it but there's no **** at all I can see where it might have went by the throttle body in between carbs 2 and 3
Old Apr 10, 2019 | 03:30 PM
If I hold forward on the hand throttle it will idle down buy when i let go it revs right up and the screws on the throttle line are in as far as they can be
Old Apr 10, 2019 | 05:53 PM
Phil314's Avatar
Ok, well if the idle speed **** is completely missing, then that's not your problem, lol.
Sounds like your cables are hanging up (they are too tight).
If the adjustment is all the way in on the inline adjuster by the throttle handle, then you need to adjust the throttle cable where it attaches to the carbs.
That will give you more slack in the cables, then you can make fine adjustments with the inline adjuster.
Also make sure the throttle cables are not twisted and not pinched under the airbox. That will keep your throttle from returning to idle.
Also make sure the throttle cables are lubed and not dry or completely worn out.
Also make sure the throttle grip is not rubbing on anything. Aftermarket grips tend to do that.
Also dirt and grim get under the throttle tube, good idea to take that off and clean under it.
The throttle when working correctly should snap shut from a half throttle position.
If you get it work properly, then you'll need the idle speed **** to keep the idle from being too low.
93MitsuVR4
Jun 7, 2011 12:57 PM
cgalvan
Sep 28, 2010 02:56 PM
sonicbluerider
Mar 18, 2009 11:09 AM
phishstyx
Nov 29, 2007 07:52 PM
ddaren
Feb 16, 2007 05:45 AM
