Help with a center exhaust
Old Feb 22, 2008 | 12:37 AM
blacktek's Avatar
Default Help with a center exhaust
Hi everyone!
I've been googling around, but I still haven't found any information on building a new pipe line to get the exhaust coming out from the rear above the tire (as it is stock on the newer models).
Has anyone done this or have any example?
I have a pretty small Laser K2 slip-on, which I think would fit nicely there, but I'm worried about the space that will be left between the hugger and upper rear parts, because the pipeline would have to go from the side to the center.
Check out some pics on my F2 on: http://www.tag-team.org/hondacbr/kuv...2007/index.htm(sorry, the site is in Finnish).
I'm rebuilding the bike right now (it's winter here) with a new paint job, xenons, new lights, modified gauges, etc. etc...
Old Feb 22, 2008 | 01:00 AM
ctm's Avatar
ctm
Default RE: Help with a center exhaust
Going for looks or perfomance
Old Feb 22, 2008 | 01:15 AM
blacktek's Avatar
Primarily looks for now. At least a longer exhaust pipe can't be more efficient than a shorter one.
The previous owner has changed the nozzles and I changed the slip-on, mut otherwise the engine is stock and the power is enough for me...
Old Feb 22, 2008 | 09:34 AM
SpecR's Avatar
It would probably look like crap, if you could even get it to work.
Unless you feel like completely redesigning your motorcycle.
Old Feb 22, 2008 | 11:51 AM
Dj_Squatch's Avatar
I have only seen one f2 that has an underseat using the stock swingarm...and I cant tell where it comes from...but it most likely runs through a bunch of twists to get there........if you search for the member rsp919 on here he has a dual underseat....but he also has a custom singlesided swingarm...as well as everything else on his bike being custom. If I where you I wouldnt bother with it unless your going for a showbike and redoing everything
Old Feb 22, 2008 | 01:31 PM
SpecR's Avatar
Like I said, you'd have to either ghetto-rig it, make a major change in the bike's design.
The way I see it, a bike either has one, or doesn't. It's not something you can add as an afterthought.
Plus, I think having the side muffler lowers your COG anyway... and if you're worried about ground clearance, get a triangle exhaust.
Old Feb 24, 2008 | 07:05 AM
mobius9's Avatar
That's not entirely true. Hotbodies makes undertail exhaust conversions for bikes that have a side exhaust... like the 954.
It is possible, but you have to bend the pipe around the swingarm (the hotbodies kits do the same thing). Here is the only F2 I've seen... other than rsp's nutzo bike
Here are some fitting pictures I took, a muzzy donor exhaust off an old F1
I'm 140lbs. It took about 350lbs to almost make the shock compress fully to the point where it touched the exhaust... so I guess your shock settings and weight matter... but point of the matter is it can hit! (what if a passenger is riding on the rear?!) (I am running an ohlins btw)
It never would touch unless I decided to jump my bike or something... but it still is possible, just something to keep in mind. Since this a scrapper exhaust I'll probably have a midpipe made up anyways so I can place it here. It looks pretty damn good under the seat imo. I'll take some more pictures if I ever go through with it. I repaired the exhaust about 5 months ago and have put the project on hold.
Old Feb 26, 2008 | 07:05 AM
blacktek's Avatar
Yes, well I'm aware that it would take some major mods to fit (also because I have the hugger installed) and I've also been measuring the 'worst' possible case as what comes to a fully compressed shock.
Maybe it would be necessary to make some sort of stopper with a rubber cover that would stop the 'incompress' just before the muffler will hit something
Mobius9, thank you very much for these pics. Let us know if/when your project will make progress...
randysherwood
Jun 14, 2013 04:55 PM
f4imgunadie
May 7, 2009 01:20 PM
bicklebok
Sep 4, 2008 09:44 AM
MC_spirited
Mar 20, 2008 05:54 AM
ampfp
Nov 21, 2006 04:11 PM
