headlight problems
Old Aug 20, 2006 | 04:20 AM
undercoverbrother's Avatar
Default headlight problems
noticed this a couple of times.opened the throtle and headlight went out for a split second and comes right back on, happen to any1?
Old Aug 20, 2006 | 12:12 PM
Syphen's Avatar
Default RE: headlight problems
check your connections. You can get to them with the windshield off, pull that rubber flap behind you guages up and back. You should be able to see a row of connections. I think its 2nd one in from the right or something controls all the lighting on the bike. When mine was loose, my lights went out when I was on the highway at night: scared the crap outta me.
just make sure that all the clips and things are held together.
Old Aug 20, 2006 | 03:54 PM
checked them twice b4.they're all in snug.and i think the guages stayed on when the headlights went out(for a split second).doesnt happen frequently, or even often, and it only happened after long rides when im at about 25 and go to twist wrist. since it was like a one in a million thing, and i have not been able to reproduce it.i just wanted to know if ne 1 ever had this
Old Aug 20, 2006 | 06:00 PM
jbax's Avatar
Haven't had that on my bike, but I had something similar on my car. Come to find out, the filament inside the bulb had a loose connection, so only under very particular circumstances would the light go out and then come back on.
I replaced the bulb, and the problem was solved.
Don't know if it's the same on the bike, but good luck.
Old Aug 22, 2006 | 04:29 AM
uHaulF2's Avatar
thanks for the heads up- I am gonna check mine, since I will have the fairing off anyway
bigboi18184
May 10, 2009 11:08 PM
xmurfx
May 9, 2009 04:03 PM
Ace_f4i
Mar 20, 2008 07:51 AM
cbrrrfan
Aug 25, 2007 10:33 PM
lldreams
Apr 10, 2007 03:48 PM
