headlight problem
Old Aug 22, 2009 | 09:10 PM
77vetteguy's Avatar
Default headlight problem
Im having a problem with the headlight kill wire under the on off switch. It keeps coming off. Would it hurt anything if i just connected the 2 wires together so the light stays on when you hit the starter?
Old Aug 23, 2009 | 10:10 PM
77vetteguy's Avatar
bumped
Old Aug 26, 2009 | 08:42 PM
antatious's Avatar
I'm not sure what year it started, but I thought around the 70s every bike made must have the headlights on at all times. So yeah, you should connect that so it is on at all times if I am understanding you correctly. When you turn the key to on, the light should turn on even if you dont start the bike.
The light switch is for high/low beams, not to turn the light on or off, if thats what you are thinking... Or are you talking about the ignition switch on the right side?
Old Aug 27, 2009 | 11:23 AM
Bently600's Avatar
I think he means the ignition switch on the right. If you did that you would lose some cranking power to the starter at the very least...
Old Aug 28, 2009 | 05:16 PM
77vetteguy's Avatar
thats what i was looking for. the wire has come off before but i fixed it. the other day it didn't come on i think because the starter switch was stuck down. that switch has been sticking lately so i should probably check that out.
cajun rider
Mar 22, 2012 07:37 PM
rnora1
Jun 11, 2009 10:28 PM
bottlebaby
Jun 4, 2009 09:38 PM
josemiguel
Oct 20, 2007 09:06 PM
