Fuel leaking!
Old Oct 24, 2006 | 07:00 PM
Ar15 guy's Avatar
Default Fuel leaking!
I went out earlier today and noticed a nice puddle of gas under my bike.
I take off the plastics and notice gas running down the fuel lines were they connect with the carb. The line is new (1 week old) 3/8' automotive fuel line. It fits tight. Is it supposed to be 3/8' or 5/16'? I took the lines off...snipped them and reinstalled...same effect.
Both of them are doing it. I was thinking maybe there was o-ring seals on the swivel fittings that are on the carb?
Old Oct 24, 2006 | 07:44 PM
Hoosier1104's Avatar
Default RE: Fuel leaking!
If there is a extension off the carb just use a circle clamp were you tighten it with a screw driver.
Old Oct 25, 2006 | 01:00 AM
Ar15 guy's Avatar
Looks like one of the orings must be leaking on the swivel part of teh carb. There is some side to side movement so I'm sure thats what it is.
Wish I would have known when I had the carbs off the first time. Oh well. It really to cold to ride anyways. But I have been anyways.
Old Nov 1, 2006 | 03:38 PM
racer212's Avatar
My bike did the same thing when I restored it. A mechanic buddy told me to heat the crap out of the carbs with a heat gun (mind the fuel or you'll get a fire) but heat the carbs (and hence the o-rings) WAAAAYYY up. They'll soften a bit and when they re-cool they wont leak anymore. Worked like a champ!
Old Nov 2, 2006 | 12:50 AM
Ar15 guy's Avatar
I ended up pulling the carbs apart and changing the O-rings. It was a PITA but its all good now.
Old Nov 2, 2006 | 09:26 AM
mikequinn's Avatar
chances are the diaphram has gone in the fuel ****... there is a little drain hole at the bottom of the fuel tap, is the fuel leaking out of there??
platnumbob
Jul 5, 2014 09:57 PM
Mulkxican88
Nov 14, 2013 05:23 PM
MegatronousPrime
Apr 29, 2012 09:51 PM
robbiebgraham
Mar 8, 2011 02:47 AM
haak30
Sep 17, 2008 05:24 AM
