Fuel key turn which direction?
Old Feb 13, 2018 | 12:45 AM
OldSchoolCoolF2's Avatar
Default Fuel key turn which direction?
Trying to revive an F2 that's been sitting for past 6 years. Absolutely can't get the gas tank open at this point. Have sprayed WD-40 several times over past day. Can someone at least tell me which direction the key is supposed to turn to open the tank... clockwise or counterclockwise? What are my options if I can't get the tank unlocked?? Thanks
Old Feb 13, 2018 | 01:35 AM
CaBaRet's Avatar
Should be counter clockwise, try undoing the hex bolts around the lock see if it will lift out, but don't force it, a little bit of pressure on the cap each time you try to turn the key should help
Old Feb 13, 2018 | 08:05 PM
So far it seems to be clockwise. I'm now able to turn key from noon position (standing on left side of bike) to 5:00. Can someone tell me how far is the key supposed to turn before it pops open? The lip where it says "Push Lock" is trying to come open but nada. Removing bolts around lock didn't help matters. Thanks
Old Feb 13, 2018 | 09:58 PM
74demon's Avatar
Should be 90 degrees. Try turning it only 90 and giving it some encouragement. There should be some resistance when turning. If it spins easy, the lock isn't turning anything inside.
Old Feb 14, 2018 | 06:19 PM
EchoWars's Avatar
Might be in the market for one of these:
https://www.ebay.com/itm/FRONT-Gas-F...19.m1438.l2649
Looking at one myself...the key thing gets to be a hassle.
Old Feb 21, 2018 | 04:42 PM
Thumbs up
Thanks for the replies of help. Finally got it open then removed. Gunked up:
Soaking in vinegar FTW:
Old Feb 22, 2018 | 01:56 AM
CaBaRet's Avatar
Good stuff vinegar , use it all the time for soak cleaning, cheap too, glad you got it sorted
Old Feb 22, 2018 | 09:24 AM
Hawkwind2016's Avatar
Good job, that vinegar has worked well.
Stunt'n70f4i
Sep 6, 2010 10:52 AM
madeincanada123
Apr 9, 2009 07:03 PM
hypeshipe
Apr 1, 2009 11:31 AM
maxperformance
Jul 11, 2008 09:54 PM
A 929RR RIDER
Mar 28, 2007 12:31 PM
