Front Brake Shims
Old Jan 21, 2008 | 08:34 PM
Gow's Avatar
Gow
Default Front Brake Shims
sorry guys, i don't actually own a CBR but my honda hawk has an F2 front end. When installing the front rotors I encountered allignment problems. According to the schematic there is a shim between the disk and fork (actually 1 for each mounting bolt) one of these shims was not enough to line things up correctly. Is there any reason i cant stack these shims and is that the correct way to fix this problem. thanks for any input
Old Jan 21, 2008 | 09:10 PM
kjohnson's Avatar
Default RE: Front Brake Shims
You using an entire F2 front end,or a Hawk/CBR soup of parts?
Old Jan 22, 2008 | 09:54 AM
Gow's Avatar
Gow
I started with a full CBR front end, I used the forktubes, upper triple, disks,calipers, and wheel. The only hawk parts are the lower tripple (width was the same, and it seemed neccessary to get it to fit correctly against the head tube) and the hawk clip-ons, neither of which seem to differ enough from the cbr to affect allignment.
Old Jan 22, 2008 | 12:07 PM
kjohnson's Avatar
Sounds like something's bent.Tubes or lower triple maybe.Make sure the bottom of the lower triple is flat.
This is like giving /getting a haircut over the phone .
Old Jan 22, 2008 | 12:52 PM
Gow's Avatar
Gow
first off, thanks for your input, I determined as best I could that everything is straight, the caliper mounting bracket is the only thing i think could be bent, if that isnt the case how bad is it to stack a few shims to line everything up, or washers at the caliper would do the same thing, are either of these options safe (relatively)or effective
6doubleohf3
Oct 25, 2009 09:01 AM
phillycbr
Sep 2, 2009 10:35 PM
FLYOU
Jul 13, 2007 08:12 PM
JJHUNSECKER
Sep 16, 2006 03:22 AM
aeroworks
Feb 23, 2006 01:21 PM
