fatter tire
Old Jan 13, 2011 | 05:37 PM
PlayfulGod's Avatar
Originally Posted by Dissevered
Are you being sarcastic or are you just dumb? lol...
Liter bikes uses 180's because of the much higher HP and the rear STILL slips out. Our little F2s are what, 60hp less than the liter bikes?
I run 160's at the track and do just fine. I had a friend with a gsxr 1000 who couldnt take me in the turns.
Whatever you do don't squeeze bigger tires on smaller rims. You mess up the profile of the tire and get horrible handling. If you are horny for big tires get a bigger rim, and expect slower handling.
umm 1k's come with 190's on em
Old Jan 13, 2011 | 06:38 PM
underground-mpyre's Avatar
Peoples weight and riding style do go a long way while on a track. So a 600 and a 1K could even out. You do lose Hp with wheel momentum, but can't sacrifice the contact patch/ surface area. I would choose larger grip/contact patch if I can power threw a corner without any worry. So through logic, I am not dumb.
Check the posts disservered, CBR900rr 5.5 inch 180 rim will fit on the F2/F3 swingarm.
Old Jan 13, 2011 | 07:09 PM
Dissevered's Avatar
I was talking more about the 900rr which i thought had 180s? whatever, not the point I was trying to make ^_^
Old Jan 13, 2011 | 07:15 PM
Dissevered's Avatar
My point is that the F2 does not have the power to lose the rear wheel so what is the point of increasing your contact patch. Again too, the biggest concern is putting larger tires on smaller rims, screwing up the profile of the tire, in turn giving you a worse contact patch and horrible cornering.
Old Jan 14, 2011 | 01:53 AM
iJapanesey's Avatar
Everybody, but Jesse is wrong! CBR900rr 5.5inch 180 has been proven to fit! The faster you go, you will need to get more lean down on the track. So that is why you need a 180 for more lean and grip(stability) for cornering. The more you corner/ lean, the faster you can get lap time, the fatter the tire.
As far as street riding, 160 will obviously work.
I give up
Old Jan 14, 2011 | 12:42 PM
bambam's Avatar
whats wrong with the 160 ? an F2 doesnt need a bigger tire unless your olny out for looks. JMo
Old Jan 16, 2011 | 05:37 PM
cbr814's Avatar
okay the question is what fits not why shouldnt i and the awnser to your question is a 180 is the largest ive ever seen fitted on a f2 i road on it and its nothing noticlbly better or worse i run a 170 its what came on my bike i will prob replace it with a 170 or a 180
Old Jan 17, 2011 | 12:48 PM
kinglee86's Avatar
Thanks
Old Jan 17, 2011 | 01:07 PM
PlayfulGod's Avatar
a 180 may fit but the profile will be all messed up unless a 5" wheel is used.
Old Jan 17, 2011 | 02:26 PM
Dissevered's Avatar
You gotta realize too that some of us here are responsible riders and also care about those of you who don't have a clue. Putting a tire on a rim it is not intended for actually reduces your contact patch, and changes how the bike leans into turns, making the change more dangerous.
