fatter tire
Old Jan 12, 2011 | 11:23 PM
kinglee86's Avatar
Default fatter tire
how big can i go on a back tire
Old Jan 13, 2011 | 08:01 AM
Dissevered's Avatar
I have seen huge tires stuffed onto F2 rims, so as for the limit I don't know.
I know you can, with little effort and tinkering, get larger rims on the f2 allowing you to safely put on larger tires but still...
Why do you want a fatter tire? It will ruin your handling. If you want it for the way it looks then by all means go for it, but don't go trying to actually ride hard in the turns or you will find yourself in a ditch.
Old Jan 13, 2011 | 08:51 AM
pepperman's Avatar
I was thinking "why" as well. That's what made me check out this post. I have an F3 and personally I really like the feel of the way the 160 I have turns in. I've had bikes that come standard with 180 rears but I really like the narrower tyre. Reminds me more of my old RGV250(still a big difference though, just a stupid comparisson) I had accept for the obvious weight difference. I totally agree with the stuffing up handling thing but if looks and just cruising around are your thing, then go for it.
Old Jan 13, 2011 | 12:47 PM
kinglee86's Avatar
naw it wouldnt be for looks....figured a fatter tire would help balance the over all bike better..
Old Jan 13, 2011 | 03:28 PM
JesseAwesome's Avatar
Welp, you thought wrong. Thanks for playing!
Old Jan 13, 2011 | 03:39 PM
nickels's Avatar
I Can't Sell On CBRF
i think you can make a 900rr rim fit on the stock swingarm...i think they take a 180 or 190
Old Jan 13, 2011 | 03:58 PM
gpfan1's Avatar
People squeeze all sizes of tires on to rims. Stock is 160. I've seen lots of f2s with 170 rears. Bigger tires usually mean slower handling which is felt by lots of people as more stabile. Watch for chain and fender rubbing.
Old Jan 13, 2011 | 04:23 PM
iJapanesey's Avatar
Don't quote me on it, but I think 170 is max. The F2 rim is 4.5 while the F3 is 5.0.
If you're on the street, I'd stick to your stock 160 for better turn in and handling. BUt a 170 would still work to answer your question.
Old Jan 13, 2011 | 05:14 PM
underground-mpyre's Avatar
Everybody, but Jesse is wrong! CBR900rr 5.5inch 180 has been proven to fit! The faster you go, you will need to get more lean down on the track. So that is why you need a 180 for more lean and grip(stability) for cornering. The more you corner/ lean, the faster you can get lap time, the fatter the tire.
As far as street riding, 160 will obviously work.
Old Jan 13, 2011 | 05:29 PM
Dissevered's Avatar
Are you being sarcastic or are you just dumb? lol...
Liter bikes uses 180's because of the much higher HP and the rear STILL slips out. Our little F2s are what, 60hp less than the liter bikes?
I run 160's at the track and do just fine. I had a friend with a gsxr 1000 who couldnt take me in the turns.
Whatever you do don't squeeze bigger tires on smaller rims. You mess up the profile of the tire and get horrible handling. If you are horny for big tires get a bigger rim, and expect slower handling.
