F3 engine in F2
F3 engine in F2
Sorry if this is a FAQ, but I'm new to the CBR scene.
I did search this forum, but I couldn't find the answer(s) I was looking for.
Basically, I got my hands on a 1993 CBR600 with a blown engine and I'm looking for a replacement.
Will the F3 engine bolt right up and if not, what mods are required?
I've got a line on an F3 engine only - do I need any F3 electronics to make this work or will my F2 stuff work with or without modification.
Again, sorry if this is common knowledge if someone could point me in the right direction I'd appreciate it.
-Fran
-Fran
RE: F3 engine in F2
the only thing that the motor is going to have is the electronic speed sensor. everything is the same, bolts right up.
i should know i swap motors with a 97 then over the years swapped everything else to a 97-98 body style and wire harness for all the toys that a f3 has and not a f2.originally its a 94 f2.
RE: F3 engine in F2
well your using your original cluster so just leave cut off. your mph gauge comes from the front rim (speedo cable) . when u want to upgrade your cluster (meter) you will need to change your wire harness to a f3, any year for the electric speed sensor to work...and all the other parts to upgrade....
lanceam24
F2 Tech
02-21-2011 11:45 AM
98formulaLS1
08-24-2009 10:04 AM
