Excessive gas smell
Old Mar 9, 2010 | 11:35 AM
CrashTECH's Avatar
Default Excessive gas smell
Seems that when run the garage ends up smelling a lot stronger of gasoline than it should. Any thoughts or is this a normal thing I just need to get used to?
Disclaimer: Never owned a bike before, so in some respects not sure what to expect.
Old Mar 9, 2010 | 11:53 AM
Sand.Man's Avatar
Running rich, have your carbs tuned by a professional.
Old Mar 9, 2010 | 11:56 AM
CrashTECH's Avatar
Any est on cost?
Old Mar 9, 2010 | 12:52 PM
Sand.Man's Avatar
I don't give estimates, you can try calling a bike shop near you for an estimate
Old Mar 9, 2010 | 06:07 PM
CrashTECH's Avatar
Well, I won't have any idea if what they "charge" sounds reasonable. I wouldn't figure it would be more than a couple hours labor?
Old Mar 9, 2010 | 06:17 PM
Sand.Man's Avatar
It's tough to say, if you want your bike to run perfectly smooth and be perfectly tuned it needs to be done on a dyno for best results.
You can try to do it on your own with a jet kit and spend countless hours testing, tuning and checking your spark plugs but that is never very accurate.
$400-$500 for a dyno tune would be my "estimate" ... The results are astonishing, it's worth it in my opinion.
Throttle response will be crisp, and you'll have a very smooth powerband with no flat spots.
Old Mar 9, 2010 | 08:30 PM
CrashTECH's Avatar
I don't think I have anybody around here that could do it that precisely. Unless dealers have dynos... we don't have much of anything "performance" related...
Figures. I'll have to start looking for shops around here.
Old Mar 10, 2010 | 03:59 PM
CrashTECH's Avatar
Local place said ~$350. So I am going to go that route. I'll have em put in some new plugs while they are at it. One less thing for me to do.
Old Mar 10, 2010 | 08:14 PM
Krux's Avatar
Wideband o2 sensor on the exhaust and running it at 14.7 idle and around 13.5 wot. You can do it this way and also make your own jet kit seeing what ratio your getting that way. Richer is better than leaner. Leaner more detonation and it will run hotter. Rich you will loose power and promote carbon build up by un-burnt fuel but its safer.
Old Mar 11, 2010 | 07:08 AM
CrashTECH's Avatar
Can you elaborate a bit more on that?
I was just figuring since it is a 92, I am at least the 4th owner, and the guy who had it before me didn't put many miles on it and it sat a lot... it might just need to be tuned properly.
STANJ2
Oct 28, 2014 03:11 AM
bdahl77
Jan 11, 2011 10:21 PM
NateDieselF4i
Oct 21, 2010 08:31 PM
MojoWrangler
Jun 11, 2007 11:27 PM
CompFX
Jul 25, 2005 12:03 AM
