The evolution of my f2
Old Feb 13, 2011 | 09:27 PM
Dougwayne's Avatar
Default The evolution of my f2
Heres what I started with two years ago. Pretty much stock.
About six months ago she transitioned into this-
Hate to say it but about a week after I painted it white I layed it down... So along with repainting I decided to do a tail swap- 05 gsxr 1000 race tail.
This is pretty much the concept of what Im shooting for, a raised subframe with modified mounting brackets.
The tail section I picked up on ebay busted up. Ive already begun to repair the cracks and remove the shotty plate/rivet job it came with. Along with this body mod Ive decided to install a stage 1 jet kit, new shorty exhuast, integrated tail light, repainting, f4i shock, and standard mantinance. Pulled the radiator off for a flush and completed the valve adjustment.
Here is where the projetct is currently at
As of this evening I sprayed the frame with paint and its ready for the clear.
Ill post some new pix as the work goes on. Thanks for looking!
Old Feb 15, 2011 | 11:08 AM
cbr814's Avatar
nice tail you should get on customfighters forum great site and they do tails all the time
Old Feb 15, 2011 | 05:40 PM
Dougwayne's Avatar
Thanks bro, Ill be sure to check it out.
Old Feb 15, 2011 | 09:00 PM
F2Resurrection's Avatar
where did you get that chain gaurd top pic.
Old Feb 16, 2011 | 06:16 PM
DagonRais's Avatar
i stubled on this today similar to what he had
http://www.jdacustom.com/store/home.php?cat=301
Old Feb 16, 2011 | 09:17 PM
Dougwayne's Avatar
Not sure where the guy got it before me but it looks the same as this one on ebay-
http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
Old Mar 1, 2011 | 07:43 PM
antatious's Avatar
Let's see some more progress pictures! It looks like you fitted that GSXR tail really well. And didn't even cut any frame off- nice job. Have you figured anything yet for the rear lights or battery compartment?
More progress pics. I'll show you mine if you show me yours ~_-
Old Mar 19, 2011 | 10:10 PM
Dougwayne's Avatar
Had to go outta town for a while but heres what Ive done the past three days.
GSXR tail is really going good. Reinforced the fiberglass, cut out those aluminum hold brackets, and lastly more sanding than I really care to mention...
You guys will prolly notice in the old pix the plastics were matte white but Im changing all that up with this one. Should make the bike stand out far better than before.
First clear coat on these and several other pieces this evening and hope to knock out the rest tomorrow. The tire hugger has been modified with the upper section brought to a point and painted black. Ill throw up a pic of it when its complete.
My battery box had to be cut down for it to fit in the frame. Installed it and the F4i shock today.
Lastly I cut 8 1/2" off the pipe. Gonna try and find some aluminum for a stay bracket and Im thinking about reinstalling the Yoshi plate on the remaining pipe. I was going to mount a stub exhaust but it didnt fit the lines of my bike. Engine mods are slow going as Im still waiting for parts to get here.
Old Mar 20, 2011 | 08:07 PM
YankeeBravo's Avatar
Nice work on the tail section. I look forward to seeing more of this build.
Old Apr 16, 2011 | 07:44 PM
Dougwayne's Avatar
Update! Toss out a few pix of how this project is going.
The stock mid pannels provided the perfect flow between new and old. I prefer to use the older stock parts if I can. They may need modification but at least it keeps some of my 91's original look.
I started the cut with a die grinder but the low rpms of a cordless drill kept the cut-off wheel from melting the plastics and saved a lot of time. The plastic stay brackets that are on the waste plastic Ill weld to these mid pannels.
Again, I went with the old but freshened up the lines. The f2 is all about curves so the rear needed edge to compensate for the sharper tail section.
As you guys can see most of the body work has been completed, new grips, seat, exhaust bracket, and mirrors. Whats missing are turn signals, undertail, and Im not finished with the can. I want to rivet the Yoshi plate back on.
The wires that are visible in the bat box have been cleaned up since this shot.
On the first trial run I broke down and replaced the battery. Turns out its something else in the system, stator or reg Im guessing. The bike is 20 years old still running the stock electronics and had been operating great. Ive ordered a stator, reg, and solenoid and will update all of the old stuff.
This fall I may add some more modifications so any ideas would be great.
koko_TL1000R
F2 Media
108
May 28, 2017 02:50 PM
ERM324
Sep 10, 2009 11:35 AM
TARLASHA
Sep 27, 2007 08:28 PM
Infamousdiz
Jul 14, 2005 05:55 PM
