engine swap.
Old Apr 29, 2008 | 09:28 PM
cowboy from hell's Avatar
Default engine swap.
ok iam always on the lookout for more power so today i found a 97 f3 engine for 500 bucks. is there anythin special u gotta do to mount it in an f2 or is it bolt up? also is there any csubstancial power gains between the f2 and f3 or shuld i save my money fer a bigger bike?
Old Apr 29, 2008 | 11:05 PM
FNQuickF2's Avatar
Default RE: engine swap.
Not enough power difference between the F2 and F3 600cc engine to justify $500.00.
RB
Old Apr 30, 2008 | 07:36 AM
MikeInCtown's Avatar
Not sure, but the CDI box may not allow it to work depending on the sensors and how they read. Also the speedos are different so you will lose functionality unless you also get the F3 harness and dash. I'm with FNQuick in saying $500 isn't worth it.
Old Apr 30, 2008 | 07:37 AM
Oh, if you really want to spend that $500, do it on shock upgrades, tires, and a chain conversion to lighten the bike up. those would be worth more than a few hp and all that work replacing an engine.
Old Apr 30, 2008 | 03:19 PM
bindelsf2's Avatar
do the 900 swap then. i got the 900 engine for 500.00 and sold my f2 engine for 650.00 and its not all that hard to do.i have numerous write ups on it on here.
Old May 1, 2008 | 08:45 PM
kjohnson's Avatar
Nope.
My F2/3 hybrid racebike has an F3 motor carbs and airbox.It runs on F2 coils,harness and CDI.
The F3 motor will go right in.You will lose the speedo function though.
The conrods on the F3 are beefier,as are the crank journals.The tranny's synchro is nicer,especially when you are going through the gears fast.F3 motor is worth it,IMO. I'm thinking of putting one in my streetbike.
Old May 2, 2008 | 11:02 AM
Dj_Squatch's Avatar
Im with bindelsf2 on this one...im planning on doing the 900 swap....the price difference between the motors is practically nothing if you shop around...maybe even less, not only that but its by far the biggest power upgrade you can do for an f2. Like bindel said he has a couple write ups and I beleive rsp919 has one or two as well. The difference in work between the swaps is hardly anything as well.
Old Aug 8, 2009 | 09:45 PM
hondaking69's Avatar
Default f4
i got a 99 f4 what motor could i drop in it
Old Aug 8, 2009 | 09:59 PM
jk72180's Avatar
f2 speedo is run off the front wheel so why would you lose it just leave the f3 speed sensor unplugged
Mr. Bib
Nov 17, 2011 02:13 AM
bwiltrout
Jul 8, 2009 02:51 PM
hondaking69
May 27, 2009 07:39 PM
Workwell
Jan 14, 2009 10:02 PM
yellow_900_rr
Aug 16, 2006 01:11 AM
