cold weather problem
Old Dec 6, 2005 | 01:37 PM
wala's Avatar
Default cold weather problem
[sm=dontgetit.gif] '94cbr f2 problem..... will not start in cooler weather (below 40ish) with choke fully engauged...but if starting fluid is brought into the equation it 'll start right up; will also start no plroblem in warmer weather or after the intial start on a cold morning....runs very strong has "UNI" filter element..V & H slip on pipe and +4 degree ignition advancer on motor...just had new battery,plugs,rectifier,and wire harness installed......was told a Stage 1 jetting kit might solve the problem....but was looking for some advice .
Thanks Kurt
Old Dec 9, 2005 | 12:09 AM
hikerduane's Avatar
Default RE: cold weather problem
I tried new plugs and new pilot jets, it helped a little. My '92 has been parked since early Sept.
Old Dec 9, 2005 | 01:31 AM
Destinmatt's Avatar
I have a f2 too. The only time I've had a little problem starting was in 20 degree weather and the bike was frozen over. It just takes a bit of time and playing with the throttle. If you decide to re-jet and it helps let us know.
Ivanivanovich
Jan 7, 2014 12:16 PM
kilgoretrout
The Hurricane Saloon
81
Oct 26, 2009 08:00 PM
transambird_2000
Nov 24, 2008 08:53 AM
woo545
Riding Gear
Oct 3, 2007 03:51 PM
adams_CBR600f2
Feb 21, 2007 12:07 PM
