Clutch Issue?
Old 07-11-2008, 08:25 AM
Panic Button's Avatar
Default Clutch Issue?
I just bought a '94 F2, after cleaning the carbs and connecting the sensors to the right area the bike fires and runs great. Now the problem is the when shifting into gear I have to hold the shifter down to get into 1st and slowly release the clutch for it to hold in gear. This is the same for all the other gears. The guy said he put in a new clutch, but I'm woundering if he installed it correctly. Any insite?
Old 07-12-2008, 03:11 PM
reydelaplaya's Avatar
Default RE: Clutch Issue?
To have to hold it in gear, it's possibly a bent shift fork.
http://fiche.ronayers.com/Index.cfm/...GEARSHIFT_DRUM
Part numbers 1, 2, and 3.
Old 07-12-2008, 11:15 PM
black_98civic's Avatar
dont want to thread jack but if you have a bent shift fork do you need all 3? or is it usually one?
Old 07-13-2008, 03:27 AM
From what I understand, one forkis for 1st and 2nd, one is for 3rd and 4th, and theremaining is for 5th and 6th - though for some reasonthatstill leaves park and reverse unaccounted for.
Mine, for example is dropping out of 1st and 2ndaround 5000 rpm. I can hold it in gear past 5K, but it will still eventually pop into neutral. Holds fine for all the other gearsright up the tach. So I *assume* that I'll only need to replace the shift fork that changes first and second. Still an engine out of frametype of job... it can wait.
Old 07-18-2008, 09:55 PM
Fixed it today... Not the forks, but on the clutch side the gear detent wheel, the spring was off the lever, so it would hold the gear in place.
Old 07-18-2008, 11:31 PM
I am having trouble getting my clutch apart. I can not get the large nut off that hold everything in. Any suggestions?
Old 07-19-2008, 06:22 AM
Impact Wrench!
Old 07-19-2008, 11:58 PM
Awesome fix dude. Glad to hear you didn't have to tear apart the transmission.
Old 07-20-2008, 10:16 AM
redzintimidator's Avatar
reydelaplaya...you have reverse??[&:]..or am i just dumb and misread stuff
Nick Smith
05-01-2013 01:19 AM
sjona2011
07-07-2012 04:16 AM
amerce
08-21-2011 07:06 AM
jaCo
07-06-2011 07:10 PM
BlkF2
07-13-2007 01:03 AM
Quick Reply: Clutch Issue?
