Clutch Issue?
Old Jul 11, 2008 | 08:25 AM
Panic Button's Avatar
Default Clutch Issue?
I just bought a '94 F2, after cleaning the carbs and connecting the sensors to the right area the bike fires and runs great. Now the problem is the when shifting into gear I have to hold the shifter down to get into 1st and slowly release the clutch for it to hold in gear. This is the same for all the other gears. The guy said he put in a new clutch, but I'm woundering if he installed it correctly. Any insite?
Old Jul 12, 2008 | 03:11 PM
reydelaplaya's Avatar
Default RE: Clutch Issue?
To have to hold it in gear, it's possibly a bent shift fork.
http://fiche.ronayers.com/Index.cfm/...GEARSHIFT_DRUM
Part numbers 1, 2, and 3.
Old Jul 12, 2008 | 11:15 PM
black_98civic's Avatar
dont want to thread jack but if you have a bent shift fork do you need all 3? or is it usually one?
Old Jul 13, 2008 | 03:27 AM
From what I understand, one forkis for 1st and 2nd, one is for 3rd and 4th, and theremaining is for 5th and 6th - though for some reasonthatstill leaves park and reverse unaccounted for.
Mine, for example is dropping out of 1st and 2ndaround 5000 rpm. I can hold it in gear past 5K, but it will still eventually pop into neutral. Holds fine for all the other gearsright up the tach. So I *assume* that I'll only need to replace the shift fork that changes first and second. Still an engine out of frametype of job... it can wait.
Old Jul 18, 2008 | 09:55 PM
Fixed it today... Not the forks, but on the clutch side the gear detent wheel, the spring was off the lever, so it would hold the gear in place.
Old Jul 18, 2008 | 11:31 PM
rray12288's Avatar
I am having trouble getting my clutch apart. I can not get the large nut off that hold everything in. Any suggestions?
Old Jul 19, 2008 | 06:22 AM
Impact Wrench!
Old Jul 19, 2008 | 11:58 PM
Awesome fix dude. Glad to hear you didn't have to tear apart the transmission.
Old Jul 20, 2008 | 10:16 AM
redzintimidator's Avatar
reydelaplaya...you have reverse??[&:]..or am i just dumb and misread stuff
Nick Smith
May 1, 2013 01:19 AM
sjona2011
Jul 7, 2012 04:16 AM
amerce
Aug 21, 2011 07:06 AM
jaCo
Jul 6, 2011 07:10 PM
BlkF2
Jul 13, 2007 01:03 AM
