clutch issue....
Old Jul 9, 2007 | 10:50 PM
BlkF2's Avatar
Default clutch issue....
So my buddy wrecked his f2 pretty good. the crank got pushed thru.
so he got a engine off of ebay and I installed it.. today I finally got the rest of the parts on to make it ridable and I find that the clutch will not disengage. I have tryed to adjust it to the limits and back, with no luck.
It needs an oil change badly and I have no clue on the age of the oil, I read im my manual the old oil can cause clutch issues.. do you think I should try some new oil in it or just switch out the clutch? any advise would be kick ***
Old Jul 10, 2007 | 07:27 AM
IamEli's Avatar
Default RE: clutch issue....
I too have heard that old, dirty oil can affect clutch performance. Before you change the clutch, change the oil and adjust the clutch again and see what happens.
Late,
Elisha
Old Jul 10, 2007 | 11:06 AM
Zangetsu's Avatar
I have the same problem, but I took my entire clutch apart to replace the shift forks. Now I can't get the clutch to disengage.
Can anyone tell me the proper procedure for reinstalling a clutch? How far does the clutch plate have to be in the clutch basket?
Is there a certain torque setting I need to tighten the bolts down to?
Thanks for any help.
Old Jul 10, 2007 | 08:25 PM
BlkF2's Avatar
got it all figured out.. the clutch was shot.. I threw in the one from the old motor and it is workin great... I cant believe how damn easy it was to do a clutch on one of these..
Old Jul 10, 2007 | 10:10 PM
Zangetsu's Avatar
Help an F2 bruthah out.
How did you know how far to install the clutch plate?
Can you give me a quick How To?
I've had the clutch off and on so many times, I agree that it's easy to do, but I just can't seem to get the clutch plate in the right spot.
Old Jul 11, 2007 | 04:20 PM
BlkF2's Avatar
ORIGINAL: Zangetsu
Im not quite sure where you are getting messed up.. the clutch pack slides all the way in clutch drum. the last plate sits differently... I will take some pics on my spare motor otonight if I have some time.. I gotta go do a clutch on my car right now.
Old Jul 11, 2007 | 04:25 PM
6zoomzoom6's Avatar
ORIGINAL: Zangetsu
try using the search and find the f2 service manual posted in the F2 forum.
Old Jul 11, 2007 | 08:51 PM
Zangetsu's Avatar
bindel,
Thanks for the advice in the PM - I'll check it all out tomorrow night.
zoom,
https://cbrforum.com/m_327085/tm.htm
Thanks a zillion, bruthah!
I had no idea there was a downloadable manual available.
I was searching for "F2 clutch".
Old Jul 12, 2007 | 12:02 AM
6zoomzoom6's Avatar
that would be the manual!! helps a lot especially when you're in a tight spot and need quick answers.
Old Jul 12, 2007 | 10:37 PM
Zangetsu's Avatar
Whoo Hoo!
Thanks again to everyone who helped!
I got the clutch working tonight - took her out for a nice 20-minutes ride.
It's really nice to have 2nd gear!
