Clutch
Old Oct 25, 2007 | 03:30 PM
TripsD's Avatar
Default Clutch
My clutch just went out today. What all do i need to buy to get it fixed? Plates, springs, anything else? and if anyone has one they would like to get rid of let me know.
Old Oct 25, 2007 | 03:49 PM
freerange75's Avatar
Default RE: Clutch
Ebay almost always has this Barnett kit listed-
I personally like to do all the plates and springs at the same time. I'm also partial to Barnett from a growing up in MX and Arena-X. I did see another kit listed that even had the gasket included...
Old Oct 25, 2007 | 04:01 PM
gixxereater's Avatar
Default RE: Clutch
Barnett is good as is OEM. What happened that toasted the clutch? Broken friction? You might get away with just stiffer springs although with the price of a clutch, might as well buy new. New steels, frictions, and springs is what you will need. Soak the frictions for a bit prior to installation.
Old Oct 25, 2007 | 04:20 PM
fiddy pimpin's Avatar
Default RE: Clutch
Only use stock honda plates in my f3...
Any other brand tends to have slightly thicker plates wich make em drag ever so slightly when you pull in the clutch making neutral hard to find...
Old Oct 25, 2007 | 05:17 PM
TripsD's Avatar
Default RE: Clutch
My buddy was helping me learn how to do burnouts and after he got a good one out I went for my turn. It was at 8k and wasn't spinning at all. Then we found out that clutch wasn't even grabbing anymore. I also found out that the clutch has been changed at least 4 times in this bike. At least we got one good burnout before it went.
Old Oct 26, 2007 | 09:06 AM
Default RE: Clutch
LOL...maybe your buddy needs to learn to do them right too. Dont slip the clutch.......you need to shock the rear tire.....8k and drop that bitch. Dont slip the clutch to do a burn out........or you end up with what you have now. LOL. Dont be a ***** about burn outs....make sure it breaks the tire loose....if you half *** it you will end up on your *** or ruin a clutch.
Zandaloo
Aug 22, 2013 03:26 PM
Bordo
Sep 21, 2012 07:33 PM
02f4irider
Mar 6, 2009 07:50 PM
red stinger
Jul 19, 2008 12:17 AM
cyber00677
Jun 23, 2007 06:17 PM
