Charging problem - need help!
Old Jul 5, 2006 | 07:24 PM
F2Crazy1's Avatar
Default Charging problem - need help!
Okay guys, I'm freakin' frustrated at this point and need your help. A long story short, I recently replaced my old stator on my '93 F2 because two of the wires were melted and completely severed. I put in the new stator and ran a few tests with the volt meter to see if everything is okay. Here's what I got:
Battery not hooked up = around 13.2 volts.
Battery hooked up w/ engine idling = 14.6 volts.
Rev'd the engine and the volts dropped. This is the part I can't figure out. Theoretically, the volts should go up with the engine rev'd because the alternator should be kicking in some electricity. Before you tell me that it's the rectifier/regulator, I had it tested at a Honda dealership and the guy told me that it's working fine. So, what do you think is wrong with my charging system. Any help is appreciated!
Old Jul 6, 2006 | 06:13 AM
MT Wallet's Avatar
Default RE: Charging problem - need help!
bump for you
Old Jul 6, 2006 | 06:14 AM
MT Wallet's Avatar
Honda guys told me my charging problem had to be either:
wiring harness, battery, stator, or regulator/rectifier
somewhere in there is your problem
Old Jul 6, 2006 | 07:26 AM
mikequinn's Avatar
see other charging subject in forum
OUTPUT TEST
connect multi meter set to 0-20 volts across battery
Start engine allow to idle
slowly increase RPM to 5000
Volts should read 13v - 15.5v anything higher is definatly a rectifier/ regulator fault
LEAKAGE TEST
switch Ignition off
Disconnect negative wire from battery -
Connect multimeter set to mA (milli Amps) Between battery Neg - terminal & cable
the reading should not exceed 1.2mA DO NOT START THE ENGINE!!!!!!!!!!!
if the reading is below 1.2mA leakage rate is satisfactory.
Anything higher it's likely there's a short circuit in the wiring somewhere
when i get some more time i'll post the check for the
ALTERNATOR STATOR COILS
REGULATOR / RECTIFIER UNIT
Old Aug 1, 2008 | 01:10 AM
UpFront's Avatar
I had same thing, revvs at 14 at idle and 13.5 at 5000rpm. Switched the wires going into plastic connector. Works now..
Old Aug 1, 2008 | 01:12 AM
UpFront's Avatar
Must do short posts or won't allow me. Server f*cked. Check the plastic piece connecting the wires from your stator to your RR. Mine was fried, replaced, got messed up reading. Switched wires a few times. Fixed - 12.6 at idle, 13.5 at revv...
Old Aug 1, 2008 | 07:54 AM
MikeInCtown's Avatar
12.6 at idle isn't charging that battery at all. Fully charged battery on our bikes should be putting out 12.8 volts by itself.
Old Aug 2, 2008 | 01:15 AM
UpFront's Avatar
Today I found the solution to this problem!!!! Woohoo!! Like I said, I was also getting the 14volts at idle and 13.5 at revv. I couldnt figure it out. Then I adjusted the idle lower, like juuuuust over 1 and a half. And all the numbers went back to normal. Presto! Also, my batt was low from the testing, its back over 12.8 now..
gdjohny
Jan 10, 2014 12:09 PM
mjimenez1
Feb 6, 2010 09:28 AM
blaster
Nov 19, 2007 12:02 PM
jasonp
May 2, 2007 02:44 PM
