carbs jets exhaust matching
Old Oct 10, 2007 | 08:00 PM
toolman79706's Avatar
Default carbs jets exhaust matching
trying to get constant high rev. have d&d exhaust, running off stock velosity stacks no air box for now
If i run straight out of pipes seems to run ok but no top end,put exhaust on seems a little better but bogs on take off unless u wheelie it off,, any info on what a good set up need 0 to 15,000 constant if i can get close
just going to the drags fri. sat. for fun
THANKS if able to help... have lowered front and rear no air box for now,D&D sounds great new dunlop
17x180 going to run vp racing fuel these are just my ideas for now.....
Old Oct 10, 2007 | 09:06 PM
Fatboy's Avatar
Default RE: carbs jets exhaust matching
I think if you had an air box it would run better, have you tried it with the stock air box?
Old Oct 10, 2007 | 09:22 PM
with the stock air box it doesn't really run over 7 with out missing?
Old Oct 10, 2007 | 10:22 PM
kjohnson's Avatar
You only remove the airbox if you are using flatslide carbs,otherwise you lose power.
You're not making yourself clear.Constant high revs? Both mine can run to 13.5k whenever I want (redline is 13k).You run an F2 all the way up to 15000 rpm you will not have that motor for long,and the bike will flick you off like a freshly picked booger when it blows.
Put the D&D pipe back on it.It'll run like **** if you don't.
Put the airbox back on it.It'll run like **** if you don't.
If you have a stock motor,use paper air filters.Believe it or not,they make more power with them.High flow filters (K&N,BMC etc) only help if you have extensive motor work done (2 mm overbore,cams,nice clean headwork,polished/knife-edged crank).This stuff will cost you 6 grand to have done,if you can find someone who does that kind of work on older motors like these.Good luck,the only ones that do work like that (and do it well) only work on modern bikes.
Put all that stuff back on the bike and learn to launch it first.
Hyperblau
Feb 21, 2012 06:29 PM
Spexmad
Feb 14, 2012 10:28 PM
Mrmanr
Apr 15, 2011 11:02 PM
Brewtus
Apr 24, 2008 07:28 PM
insanearmer
Apr 10, 2006 12:46 AM
