MPG?
Old Sep 25, 2007 | 10:26 PM
AZcbrkid's Avatar
Default MPG?
Around what mpg do you all get? last tank i went to about 175 befor I had to turn it to reserve but today the bike started to bog down when I am only at 134 and I was sumwhat worried becaust i can hear gas in the tank and i know I should have plenty of mileage left but it bogged down untis I flipped it to reserve and then was running fine again.
Old Sep 25, 2007 | 10:39 PM
FNQuickF2's Avatar
Default RE: MPG?
Seems as your valve has a slight clog in the "main" tank selection.
RB
Old Sep 25, 2007 | 10:47 PM
zoogooz's Avatar
Default RE: MPG?
i would draining gas. then taking off petcock.. and maybe with compressed air can. do a reverse blow. thru reserve and main.. blow back any clogs.. then reinstall and see how it runs. if its a clog that should fix it up. but thats impressive. so far i am getting 135ish. to where i require reserve. i would love another 40miles.. could be this cold alberta climate.. and as well god knows when this bike was timing was done. or carb sync was done. i bet its running rich. does yours smell like a lawn mower ? like mine?
Old Sep 25, 2007 | 10:56 PM
elmer's Avatar
Default RE: MPG?
Mine hits reserve at about 125 depending on how I've ridden it, occasionally less. Mine has a two bros pipe and a K&N filter. I don't know if its been jetted or not. But mine was geared down -1/+2 so that could make a difference.
Old Sep 25, 2007 | 11:47 PM
FNQuickF2's Avatar
Default RE: MPG?
I get close to 150ish to a tank...Much less if I'm joy riding..
RB
Old Sep 26, 2007 | 07:41 AM
troyg3's Avatar
Default RE: MPG?
I usually need to go to reserve right at 160
Old Sep 26, 2007 | 09:56 AM
jaghunter's Avatar
Default RE: MPG?
gotten to180 with out reserve once, and then once only to 124. Riding style really really affects it
Old Sep 26, 2007 | 02:26 PM
eweppley's Avatar
Default RE: MPG?
I get somewhere between 150-160 before it goes on reserve. Always try to fill it before then, though.
Old Sep 26, 2007 | 09:02 PM
AZcbrkid's Avatar
Default RE: MPG?
Well I just got home after I ran out of gas at 158 lol yeah i guess ut just verys on the way I ride.
Old Sep 26, 2007 | 09:53 PM
CHAINSMOKIN's Avatar
Default RE: MPG?
Be interested to know how QUICKLY you have emptyed your tank!
you can use up a whole lotta fuel when you ride at WOT all day!
