MPG?
Old Sep 26, 2007 | 11:00 PM
bmg velocity's Avatar
Default RE: MPG?
Depending on how hard I ride, or how much I am in stop and go traffiic, I average about 45 mpg.
On the highway, sometimes 50 or more, with the wind at my back.
Old Oct 5, 2007 | 02:16 PM
secondgen7's Avatar
Default RE: MPG?
I commute ~33 (mostly highway @ 80mph) miles r/t each day and average 46 mpg (~165 miles before reserve -- furthest I've pushed it on reserve is 186 and put just under 4.1 gallons in it). This is with a K&N and V&H pipe (stock jetting AFAIK). Prior to the K&N I was averaging 41-42. And, as others have stated, the right hand plays a big role in fuel consumption.
Old Oct 5, 2007 | 05:36 PM
knownaschucky's Avatar
Default RE: MPG?
i get around 135-145 depending on how i ride
Old Oct 9, 2007 | 12:07 AM
redcbrman's Avatar
Default RE: MPG?
I just did a trip to the other side of the state over a mountain pass- 150 miles each way.. on the way over, I averaged 40 mpg, on the way back I averaged 50 mpg. Not sure what the difference was, speed and throttle use was fairly consistant. (80-100 most of the way )
I ran some seafoam through tonight, hopefully I see some improvements!
Old Oct 10, 2007 | 09:23 AM
thomasintexas's Avatar
Default RE: MPG?
man i get around 110-120 before i have to hit the reserve and then its like....hmmm 10 miles on that? wishing right now that mine was stock so i could get better milage as gas is expensive and my only other options to get to work are 2x 6000lb suv's....boooooo bad decision making! hahahah
Old Oct 10, 2007 | 01:26 PM
Quick6Atl's Avatar
Default RE: MPG?
I get about 160-180 depending on how aggressive I ride.... Found out what it is like to run the main tank empty, in traffic no less.. I had only had my 94 F2 about one month. Freaked me out.. then I realized i was out of gas on main and flipped the switch and felt like such a damned noob.
Old Oct 10, 2007 | 02:37 PM
woo545's Avatar
Default RE: MPG?
LOL...Happened to me 2 weeks ago, I was coming up to a red light (freezing cold at about 5:30 in the morning) as I was braking the oil light came on. I was like nuts...what is wrong. So the light changed and go to start...I didn't even notice the bike wasn't running. So I pushed it into a turn lane and switched to reserve....crank crank crank...then finally it kicked in. I knew my tank was low...but had not concept on how far it would have lasted me. I was expecting to feel a studdering or something. I guess it was just because of the braking when it died I didn't notice it because I wasn't giving it gas.
Old Oct 10, 2007 | 05:59 PM
410600f2's Avatar
Default RE: MPG?
the lowest for me was about 100 and best to date is 160 on the dot before I switched to reserve.
Old Oct 10, 2007 | 09:29 PM
redcbrman's Avatar
Default RE: MPG?
Heres a good question, what the reserve **** settings on our bikes? From my current understanding, it's pointing up for on, middle is off, and down is reserve?
Old Oct 11, 2007 | 05:33 AM
woo545's Avatar
Default RE: MPG?
RES
OFF
ON
There should be a sticker stating above. It migh subsitute ON with Main or Pri (standing for Prime). http://www.dansmc.com/gastank.htm
On an F2, the On is down and the Res is up.
