Carb Questions.
Old Sep 2, 2006 | 05:40 PM
Knight2000's Avatar
Default Carb Questions.
Couple of questions, first at all when trying to resync carbs which are the screws that need to be turn when syncing carbs. Then, will the fuel mixture be changed after a carb sync? then, is the float adjustable on this carbs? and last how hard is to clean the carbs? would regular carb cleaning spray would work?
Old Sep 2, 2006 | 10:24 PM
mikequinn's Avatar
Default RE: Carb Questions.
HONESTLY !!!! if you don't know what your doing and it sounds as if you don't asking all these questions, I would leave well alone and let someone who knows what they are doing set them up for you.. it'll be worth the money, also you can't sync the carbs without Vac, guages or a manometer....
Also a good guide before syncing the carbs' , check the valve clearances 1st.. they are usually ok, but it's worth a check,
redsilver2121
F2 Tech
Jan 17, 2014 03:51 PM
josiahafelix
Oct 17, 2013 01:21 AM
patricksmithahhh
Jan 25, 2011 06:16 PM
darkyuy
Jul 23, 2010 11:45 PM
tvvbsn
Mar 16, 2006 07:10 PM
