Carb leaking
Old Apr 27, 2009 | 06:00 PM
morbidphil0622's Avatar
Default Carb leaking
I Have a small gas leak between my #3 and #4 carb where the brown plastic "T" shaped fuel inlet meets the #3 carb.. I had an extra set of carbs and they do the same thing in the same place.. Is this a common problem? Anybody know a surefire remedy?
Old Apr 27, 2009 | 07:47 PM
Sand.Man's Avatar
Replace the o-rings if it's leaking from the fitting, if it's leaking from the hose just put a better clamp on it
Old Apr 28, 2009 | 05:53 PM
Thank you..
Old Apr 28, 2009 | 07:07 PM
Sand.Man's Avatar
You're very welcome!
Old May 1, 2009 | 12:34 PM
I ended up swapping seals from the 2 sets of carbs until I had one good set.. I cleaned all sealing surfaces and wouldnt you know it... No more leaky!!
morbidphil0622
May 29, 2012 02:33 AM
Micscience
Feb 4, 2010 01:13 PM
Chris07
Aug 20, 2008 08:29 PM
ibraud
Mar 22, 2008 05:25 PM
Badfastspeedracer
Jun 8, 2007 05:59 PM
