brakes caliper problem
My caliper are rubbing on my rotors. It hits before the brake pad. I took my frontwheel off to get a new tire. I went to put it back on and rubbed on my front wheel. I have all the spacers on, the odometer spacer, and have bleed the brakes, and got new brake pads. My rotors are not bent checked those. Anyone know of any small washer I could be missing somewhere. anything about the bearings moving. Anything, need to go riding.
Like 6zoomzoom6said you need to read the manual on adjusting the front wheel after removal. You have to use a feeler gauge between the brake calipers and rotors to get the correct clearances
