Bike stuck in gear?
Old Feb 2, 2008 | 01:33 PM
amig's Avatar
Default Bike stuck in gear?
[hr] what would be the problem of a bike getting stuck in a gear?
im rolling to a stop i down shift and then suddenly my bike gets stuck in 3rd gear...i tried moving it back and forth while trying to shift and it doesnt want to go into a lower gear, so i end up having to start in 3rd gear after a stop, thus burning my clutch...
thanks[/align]
Old Feb 2, 2008 | 02:28 PM
SpecR's Avatar
Default RE: Bike stuck in gear?
You're going to have to pop off your clutch, remove the shift linkage, and inspect it... the shift from 1st to 2nd is the most violent, and if the shift drum breaks, you've have problems. If the shift drum or shift linkage isn't broken, you've got to pop the oil pan off and check the shift arms.
If THEY'RE ok, check the teeth on your gears.
Old Feb 2, 2008 | 02:37 PM
SpecR's Avatar
Oh wait, you're going to have to take off the oil pan and the shift arms if you want to take the drum out...
SamRogers8611
Feb 29, 2012 07:12 PM
Akol47
May 3, 2011 07:50 AM
GTiVR6
Mar 31, 2009 05:35 PM
