90 hurricane stuck in gear help??
Old Mar 28, 2009 | 08:46 PM
GTiVR6's Avatar
Angry 90 hurricane stuck in gear help??
Just pulled her out from storage, oil change, and all the fluids checked. Went for a little night ride and started acting funny like the clutch wasn’t disengaging and would not change gear. Checked everything again the next morning thinking I missed something and went out again and the problem got worse. Now I only got first and second and it won’t spring back after I shift does not seem to be any abnormal nosie. Not sure what is going on so any help would be great. It only has 9,000 miles on it.
Old Mar 28, 2009 | 11:11 PM
Shadow's Avatar
It sounds like your clutch isn't operating correctly.
When did you last change your clutch fluid ?
It may be a problem with the gear selector shaft, but unlikely if it was OK when she went into storage.
Try moving the bike backwards and forwards with the engine off, and see if she'll disengage....
Old Mar 29, 2009 | 05:40 PM
swisherred's Avatar
I know im new to the CBRs, but both my 1990 1k and the '89 600 I had had a problem with the shifter not returning...it turned out to be VERY simple...(maybe not in this case, but it worth a look) the greased bushing/pivot on the shifter itself had locked up...the grease dried and the seals shrank enough to let water in and it started sticking and then stuck...wouldnt move without being forced...tore it apart, cleaned it and greased it...works fine now....I always figure you should start with the simple stuff first...
j87and89cbr600
Aug 4, 2013 03:34 PM
SamRogers8611
Feb 29, 2012 07:12 PM
Akol47
May 3, 2011 07:50 AM
amig
Feb 2, 2008 02:37 PM
