bike not running!
Old Dec 5, 2004 | 02:39 PM
ezl_oo's Avatar
Default bike not running!
Ok after I fixed the throttle cables I got a new problem. When I start the bike it runs with the choke on and idles, but once I take off the choke the bike just dies![:@] I don't know whats going on? Can someone please help. Thanks
Old Dec 5, 2004 | 05:37 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: bike not running!
have you tried adjusting the idle? Should be a **** -- righty to increase revs.
Old Dec 5, 2004 | 11:05 PM
Nipz's Avatar
how long do you let it warm out before turning off the choke? How cold is it there? how hot does the Temp get before you turn off the choke?
Nipz~
Old Feb 8, 2005 | 10:33 PM
adrunpants's Avatar
Sounds like pilot jets are blocked.
Remove pilot jets (remove with tight fitting flat screwdriver) leave to soak ovenight in water (yes water!!! is best for dissolving varnish deposits)
They must then be blown through with an airline and hold up to light to see through them , refit and should be ok.
schroncc
Jun 19, 2010 04:19 PM
ziggs189
Oct 30, 2008 07:28 AM
amarillo
Jun 14, 2007 10:45 PM
Coopz
Dec 9, 2006 12:05 AM
voodoochyl
Sep 26, 2006 02:27 PM
