Battery Problems? HELP
Old Sep 20, 2007 | 07:18 PM
y0ukeun's Avatar
Default Battery Problems? HELP
wassup guys, I'm new to the forum and i'm a complete noob with motorcycles as the streetfighter F2 i have right now is my first bike. Anyway my battery died a couple days ago so instead of buying a new one, I decided to recharge it. I recharged for an hour or 2 then it everything started fine. Then today I decided to hook up the charger again to recharge it 100%. My battery charger supposedly has an overcharge protection system but i dont think it turned off wen it was fully charged andmight haveovercharged my battery.
So basically..nothing works now. Doesn't crank, lights don't turn on, etc. I was just wondering ifit could be another problem before i go out nd try putting in a new battery? Help me out please, I'd greatly appreciate it. Thanks
Old Sep 21, 2007 | 06:16 PM
y0ukeun's Avatar
Default RE: Battery Problems? HELP
okay so i installed a new battery today..same thing. nothing turns on. so something obviously happened while i was charging the old battery. Btw I just read on the battery charger instructions that on motorcycle batteries you're supposed to use 2V but i used 6V. Anyone know what the problem is? Help me out please
Old Sep 21, 2007 | 07:14 PM
y0ukeun's Avatar
update: I checked the main fuse and found out that it was blown...but when i try to replace that fuse it just keeps blowing. any ideas?
Old Sep 25, 2007 | 12:40 AM
ohmartm's Avatar
You might have burnt apositivethat has gronded out. Look along the frame of the bike where the wires run. Hopethat helps.[sm=signs003.gif]
Old Sep 25, 2007 | 11:14 PM
zoogooz's Avatar
also check the battery once you get things fixed.. mines 0.9A 8hr charge. 4A 1hr. my charger does 2 and 4amp.. i get lights on mine but a buzzing when tring to crank.. just keep it in mind. the battery is soo small it cant take lots of abuse charge and discharge
Old Sep 26, 2007 | 11:25 AM
ohmartm's Avatar
(just keep it in mind. the battery is soo small it cant take lots of abuse charge and discharge) good point zoogooz.[align=right]
[/align]
Old Sep 26, 2007 | 04:37 PM
CHAINSMOKIN's Avatar
Sounds like a short.
I know it sounds dumb but, Have you got the terminals the right way around?
SnakeTheLegend
Oct 15, 2010 09:40 AM
97turboeco
Dec 14, 2009 01:18 PM
rslaney
Sep 17, 2007 03:02 PM
bamzo25
Apr 28, 2007 10:30 AM
cassimero
Aug 2, 2006 01:26 PM
