battery
Old Aug 25, 2006 | 04:39 AM
wetwillymd's Avatar
Default battery
hey everyone. i have a '93 honda cbr 600 f2. first question- if your battery goes dead and u charge it . and rev the bike while still in neutral actually recharge to bike.
2 question- from the bottom of the gas tank on the out side there is 2 tube just out there r they suppost to be just hangin or do they need to be connected to something. or is that the breather. its called fuel tank drain tube and fuel tank vent tube. does having a liitle gas let even if u switched it to rerv drain the gas out because mind doesn't start maybe the spark plugs need replacing because when i hit the start it make a noise but i think there is no spark. to start the thing.
Old Aug 25, 2006 | 05:25 AM
yipperzz's Avatar
Default RE: battery
if you rev your bike, it won't charge much. i suggest you buy a battery tender/charger. check it with a voltmeter.
and on my bike i don't have a vent tube. it should be fine.
you could have a lot of problems. i would check the battery first since it's the easiest. then you can troubleshoot it from there. i thought i had one problem on my bike when i picked it up and i ended up fixing 3 things to get it to run right.
estate4life
Dec 4, 2012 11:08 PM
jharbinson
Dec 31, 2009 09:23 AM
xander071584
Dec 24, 2008 01:45 PM
njdjh2o
Apr 11, 2008 07:20 PM
MDZ600F4i
Oct 18, 2006 07:50 PM
