ATTENTION all F2 owners
Old Jun 24, 2007 | 02:39 PM
CBRFEAVER's Avatar
Default ATTENTION all F2 owners
Im not sure if the F2 tail seperates like the F3 but if so i have the salution ...My uncle the wonderful mr cnc mechine finally figured out how to keep the tail from seperating with a small bracket on each side when i say small its small and as soon as my bike is back from body work and i make sure every thing is on the ok and all works well this item will be up for sale .... price will be set after testing but here are a few pics to settle the "what does it look likes" remember all the lil tabs on the center tail chip off or crack off this wont its made of metal and bolts where that lil tab broke off with flush mount or regular head bolts your choice.....take a look
[IMG]local://upfiles/12817/C76AAE03C9E24F7B927099A347490836.jpg[/IMG]
[IMG]local://upfiles/12817/1C139C1C1F8940FDB645EEF6CEA2BB8C.jpg[/IMG]
Old Jun 24, 2007 | 05:59 PM
FNQuickF2's Avatar
Default RE: ATTENTION all F2 owners
Not too sure I know what your talking about...F2 & F3 plastic is different, so we may not have that same problem...
Looks good!
RB
Old Jun 24, 2007 | 08:18 PM
MikeInCtown's Avatar
If you mean seperate like the two rear sides don't quite clip perfectly into the back flat part, I feel the pain. Mine sits almost there, but you can see a gap. If these will work on the F2, I'm in for the repair pieces.
Old Jun 24, 2007 | 10:48 PM
FNQuickF2's Avatar
So you'd be talking about these spaces...
Mine are perfect...
RB
Old Jun 25, 2007 | 08:53 PM
CBRFEAVER's Avatar
Have any of you guys pull a wheelie and come down and feel somthing flapping well its your tail that has seperated if all tests work out for the good this will prevent that
Old Jun 25, 2007 | 11:29 PM
felk27t's Avatar
I have a meier left side panel and I have a gap...will it work with meier body parts???
Old Jul 3, 2007 | 11:43 PM
jay4now's Avatar
If I understand correctly what your uncle is trying to do, it seems as though your suppossed to attach one screw to each fairing and then torq down screws when you find specific gap. Nuts fastened to the inside of your fairing seem like the correct hillbilly way to drive your screw into, screwing into plastic would be terrible as would bolting through be a headache.
Old Jul 4, 2007 | 08:58 AM
I got a chance to look at the side last night on mine. I can't keep the sides attached perfectly because the little hole on the side where it attaches to the pin was cracked. I'm wondering if a metal part can't be epoxied into place that would replace that snapped part?
Old Jul 4, 2007 | 11:04 AM
bmg velocity's Avatar
You can manipulate the grommeted metal flange that holds each side tail section bending a little in and out, installing the side piece seeing if the direction you are bending was the right or worng way. And don't bend it more than say 1/32 to 1/16 an inch or you'll eventually fatigue the metal.
I'm talking about the metal flange, attached to the subframe that holds the plastic nipple..the one just above the swingarm.
I had mine almost flawless...
Now have a new race tail. Carbon Fiber...beautiful and causes some people to cry like babies for some reason. [sm=boohoo.gif]
Old Jul 7, 2007 | 10:00 PM
CBRFEAVER's Avatar
https://cbrforum.com/m_328355/tm.htm read the DIY i posted up the other day it will explane every thing
Vinman911
Feb 25, 2013 05:53 PM
gotobatter
Apr 20, 2008 12:38 PM
CBRFEAVER
Jul 3, 2007 11:26 PM
christopherf
May 22, 2007 10:58 AM
