Another R/R Question
Old Apr 2, 2013 | 10:19 AM
R3define's Avatar
Originally Posted by outsider
This is absolutely normal for these bikes. Mine looked exactly the same when my mechanic looked at it, a little worse actually. Rectifiers get way too hot, especially the stock ones. The wire closest to the plug gets too hot as well and melts the rubber around it. If you looked at every stock rectifier from an F2 after about 12,000 miles, they would probably all look like this. I had the mechanic install a cheap rectifier from china and it's 10 times better than stock. Dissipates heat much better and charges just as well because of the new design. You can buy a new plug from ebay that has several inches of fresh wiring already attached.
Good to know. I think I'm just going to use spade connectors and wire it up. I had already bought a R/R from China so I just need to get to actually wiring it.
Old Jul 2, 2022 | 01:50 PM
r00t3n's Avatar
Default Overheating issues CBR 650 RA CANADA
I got a cbr 650r 2020, had an accident that bent fork and rad, all replaced by dealer and now engine overheats and coolant boiling in the rad, dealer has replaced the termostat 4 times, same problem.
Please help!
Old Jul 4, 2022 | 10:07 AM
Isn't that the definition of insanity? Doing the same thing over and over and expecting different results? Seems that there is something else wrong, or obstructing the flow of coolant around the engine.
Old Jul 5, 2022 | 06:38 PM
Phil314's Avatar
There's just so much 'wrong' packed into that one sentence.
And I'm betting we never hear from him again.
Old Jul 5, 2022 | 07:03 PM
r00t3n's Avatar
I hope someone will be able to help me out with this issue so far only complains, as for the wrong sentece you tell me 10700$ to replace the fork, fenders, front lights, one mirror, fenders and rad, due to a front colision at 30km/h and yet the coolant's boiling in the rad, you tell me mister what's wrong???
Old Jul 5, 2022 | 10:52 PM
Well, I take exception to that statement. Mine was only an observation of the dealer that keeps replacing the same part, expecting different results.
So, what kind of troubleshooting have you done? Is the Cooling Fan turning on after the engine warms up? Is coolant flowing through the radiator?
Old Jul 13, 2022 | 04:26 PM
Phil314's Avatar
I think I triggered him. Wasn't really my intent, but my post was a bit snarky.
Old Jul 13, 2022 | 04:47 PM
r00t3n's Avatar
well no leaks, fan turning when only in contact, coolant boiling, I can't trace the coolant circulation however dealer will replace a sensor that might fix the issue, will see in a day or 2. Thanks.
Bwood
Sep 17, 2018 07:59 AM
MadisonD
Aug 2, 2010 06:52 PM
Cytotek
Feb 25, 2010 11:08 AM
davethepom
The Hurricane Saloon
17
Jan 22, 2010 04:39 AM
dragracer1260
May 24, 2007 08:38 PM
